Old 12-06-2008, 08:09 AM
olds87 olds87 is offline
Is there any updates on your car Mark?
James W.
1987 Oldsmobile
Cutlass Supreme
Old 12-07-2008, 07:59 AM
Stielow's Avatar
Stielow Stielow is offline
Default Update
Just dynoed the LS7 Thur night. All stock with a cam that has tighter lobe seperation angle.
530 ftlbs @ 5000
546 hp @ 5900
Over 530 hp from 5300 - 6800 rpm.
Over 500 ftlb from 3800 - 5700 rpm
I want more torque and still a smooth idle. It idles rock solid at 650 rpm.
This was all with the stock exh manifolds and cal.
I'm building the induction an headers at Christmas. Once we get those parts and a cal we should be up to 570ish hp. We will go back on the engine dyno to sort it out. We just ran it Thur to break it in and make sure it was OK.
Mark
Old 12-07-2008, 09:28 AM
camcojb camcojb is offline
530 ftlbs @ 5000
546 hp @ 5900
Mark
sounds like your cam thoughts were correct Mark. Is this the stock LS7 cam with lsa changes, or did you go another way?
Old 12-07-2008, 10:08 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
530 ftlbs @ 5000
546 hp @ 5900
Mark
WOW!!!
that sounds awesome. Should get a good amount more with the induction and headers. GOOD LUCK!!!
Old 12-07-2008, 10:34 AM
Stielow's Avatar
Default Cam
The cam is a stock LS7 lobe wth a 115 degree lobe angle instade of 121. Seems like it will work great. And it is a validated lobe that will work stock valve springs.
Mark
Old 12-07-2008, 03:17 PM
jimbo jimbo is offline
Why the LS-7 over an LS-9?
Old 12-07-2008, 07:34 PM
Flash68's Avatar
Flash68 Flash68 is offline
Not sure how I missed this thread! Awesome project!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 12-07-2008, 07:45 PM
66LS7's Avatar
66LS7 66LS7 is offline
I'm sure this will be another inspiring car like the others have been for me. It was great talking to you & Charley at Detroit Auto Rama 2008
Old 12-07-2008, 07:48 PM
thedugan's Avatar
thedugan thedugan is offline
Mark when are you going todo another 67 or maybe your first 68?
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
Old 12-08-2008, 06:11 AM
Stielow's Avatar
I used the LS7 over the LS9 to save $10K and 120 lbs. If I would do a blown LS engine for myself I would think about an LSA when they become cheaper next year. Not as cool as an LS9 but a great value.
I would think about a '67/8 sometime to do again but I like the '69 better.
My goal is to finish Charlie's car first then get mine done this summer.
Mark
