Old 02-05-2026, 07:53 PM
camcojb camcojb is offline
3/8". You want the feed lines (pressure lines) all 3/8", only the return line from the regulator to the tank is 5/16" (though it could also be 3/8").
Old 02-05-2026, 07:59 PM
confern confern is offline
Thank you!
The Following User Says Thank You to confern For This Useful Post:
camcojb (02-05-2026)
  #23
Old 02-06-2026, 07:34 AM
dhutton dhutton is online now
Originally Posted by confern View Post
Ok, so the feed line from tank to regulator is 3/8? YES Then the return from regulator to tank is 5/16? YES Then what size from regulator to fuel rails (passenger side floor board), (5/16" or 3/8")? 3/8 Sorry for all the questions, this is my first time doing the LS stuff my last build I did all stock stuff.
Answers embedded above. As Jody said above the return line could also be 3/8. Whatever is easier.
The Following User Says Thank You to dhutton For This Useful Post:
camcojb (02-06-2026)
  #24
Old 02-06-2026, 09:20 AM
thedugan's Avatar
thedugan thedugan is offline
Here are a few options that you can do.
Use this regulator. Has everything you need to hookup the lines.
https://www.summitracing.com/parts/tnk-ls9904-kit
Buy three premade 6AN lines. Something like these, depending on the length that you need. https://www.summitracing.com/parts/fra-60261216bl
Your Holley tank hat output should be 1/4NPT. You need two adapters from 1/4 to 6an. https://www.summitracing.com/parts/sum-220647b
Check your Holley fuel rails for the size of the AN fittings used for your feed line. If its 8AN get an 6AN adapter instead.
Doug L.
68 Camaro RS/SS Conv. LSA/T56
67 Camaro RS LS2/T56 "NutKse"
The Following User Says Thank You to thedugan For This Useful Post:
  #25
Old 02-06-2026, 10:43 AM
Don’t use that FPR! Read the reviews. AC Delco or Wix only. The rest are Chinesium garbage.
Also don’t use those push on connectors with plastic parts. Get the threaded ones.
Old 02-06-2026, 12:52 PM
Thanks!
Old 02-06-2026, 12:53 PM
Awesome thank you!
Old 02-06-2026, 12:54 PM
Thanks, I always try to stick with AC Delco if I can.
