Hi HotRods,
Whew... not to much pent up frustration there. Take a deep breath. Everything is going to be fine. :-)
I did get a chance to check out your car at SEMA. Your fabrication skills are exceptional. The quality of the sheet metal work is exceptional. Overall, while I may not agree with some of your styling choices, it is an exceptional looking product.
With that said...
I question your choice of components as well as the overall cage design.
For example.
You have installed a huge HP power plant and put the power to the ground with a Jag rear end. I may be mistaken, but I don't think the overall design of the Jag rear lends itself to ultra high HP applications.
Also, in the design of you cage, you only used cross bracing in two areas that I saw. You have one in the door opening and one at the top of the cowl. Everything else is basically rectangular in configuration. Follow the link bellow and check out the cage build by Aronson’s Motorsports and compare their design to yours. I know that their car is a purpose built race car, but the same principles apply to all cage designs.
http://www.fordracingparts.com/builds/buildsindex.asp
Also, in the design of your cage, you do not pick up any of the suspension mounting points. Look at the rear of your cage for example. The coil over’s land nowhere near the cage mounting points. Also, the rear mount of the cage, at the extreme end of the frame rail, is something that you would employee only if you were using the stock leaf springs. When you went to a coil over design, you should have relocated that section of the cage to pick up the new suspension mounting point. Even at that, the current rear location is a problem in many ways, but the greatest of these is safety. This configuration is both unsafe for the passengers of your car, but also the passengers of any car unlucky enough to rear end you. You have completely eliminated any rear crumple zones and, on top of that, you carried a cage out to pick up a suspension mounting point that isn't there.
On another note, your main attachment points of the cage to the chassis are 4 rectangular tubes that cantilever away from the main chassis about a foot or so. This is not a very effective way to transmit the loads of the chassis to the cage. The main purpose of the cage is to protect the passengers in case of roll over or impact AND to pick up and reinforce the suspension mounting points. When complete, a cohesive, well designed package should do all these things and also improve the likelihood that a passenger will survive a high speed impact.
So, is your car cool? Yes, it is very cool.
Will your car do what it is supposed to do? Maybe, I am not sure what the overall performance goals are. But I go back to my earlier statement about High HP applied to a Jag rear end. I am not sure what you did to improve the internal structure of the rear but the control arm intermediate shaft configuration may suffer when exposed to excessive torque and high shock loads off the starting line.
But enough about Rosie.
You attributed a comment about “how a cage was not needed and how it takes away from all the grocery getting seat area that your so called street cars have” to me. I do not remember making such a comment. In fact, I tend to make all my Mustangs into 2 seaters, so maybe you have me confused with someone else in this regard.
And then, you said “now I see a ridiculous bar installed in the car”. What is so ridiculous about the roll bar we are installing? The drivetrain components we are using should put our car in the 10 second range. A roll bar is required. We did add some cross bracing at the front of the cage to reduce torsional deflection. Also, the rear cross bracing was installed to pick up the rear coil over and panhard bar mounting locations. I don’t think that these are outlandish concepts in the world of performance auto design.
As far as SEMA goes, MagnaFlow had two locations. The SN65 was parked next to a Foose and Coddington. I met a couple of people from LG and PT at the display, sorry I missed you.
In closing, I am not pissed. Your opinion is what it is. That being the case, you should not be pissed at any comment made by others. You invited comment when you posted your build on the forums. In fact, here was the first post…
“WHEN SUPER JUST ISN'T SUPER ENOUGH, AND ITS NO LONGER UNIQUE, THEN STEP UP TO THE ULTIMATE MUSCLE CAR......its definatley the year of the Mustang but there is going to be no comparison to what is being built in an Igloo up here in Canada...........Go to
WWW.HOTRODSRESTOS.COM
to see the Ultimate 66 Mustang that will be at SEMA”.
A comment like that invites critiques of everything you do. Good bad or otherwise.
OBTW, I can be reached at 630-762-0387. I don’t hide behind a computer either.
