Old 03-27-2005, 02:53 AM
69MyWay's Avatar
69MyWay 69MyWay is offline
Default Car in primer-paint on calendar......
I am taking all of next week off work in hopes of busting through the paint on the car. STILL waiting on the left side header to be modified for test fit, then we can go full tilt from there.
I first fitted the fenders and doors. I also applied a skim coat of ultra light filler between the door and fenders then took a 17" board and hand sanded across the two to make the door and fenders appear to have been laser cut from one piece of steel. I don't know how common it is to do this, or in my case HAVE to do this since my doors and fenders fit terrible.
I then went around and knocked out the known, or OBVIOUS dings and imperfections in the body. I took a combo of 220 and 400 wet and blocked the car down at that point slicking out some areas and more or less stripping some of the old garbage primer that had been on the car.
I spent hours taping the car off yesterday with skirts to the floor and cardboard in the grill around the weeks, under the hood, etc. to prevent over spray. I loaded the car with two good coats of primer, then three and four in the areas that had been worked. This should give me ample base to block and build from.
The next phase is to spray a guide coat on and start the perfection sanding and looking for high/low spots.
It is really starting to wear on me already but I am keeping the prize in sight.
I arranged to haul the car to a buddies paint shop next weekend for a state of the art booth and for assistance in the wet stuff from a pro. After spending $1,200 on paint materials alone I don't want to risk that with a non-heated/climate controlled booth and no professional guidance.
I would post pics, but a primer car is a primer car. Just all grey!
