Old 01-01-2007, 09:02 PM
speedshopmike's Avatar
speedshopmike speedshopmike is offline
Smile holley complete efi universal system for sale
happy new year everyone
i'm selling my analog holley 900cfm 4V fuel injection setup.
bolt right on in place of a carb; lower installed height then a carb for increased hood clearance, extremely!!! low miles, absolutely perfect working and physical condition.
comes with optional closed loop kit with heated o2 sensor (sensor in excellent condition)
knob style ecm, no laptop needed.
all manuals and other aftermarket literature included.
fuel pump included, harness, etc.
coolant temp sensor included.
this is an alpha-n system; appropriate for large-cammed engines and/or single plane intakes; vacuum signal doesn't matter.
system requires running a return line; i used the oem return line with no problem whatsoever.
TB has built-in (adjustable) fuel psi regulator.
the ecm, oxy sensor and fuel pump are still in my car running a carb; will need at least a few days lead time to remove everything.
$850 firm/ highest offer over takes it
thanks,
mike
