Old 02-23-2007, 08:47 AM
camcojb camcojb is offline
Default Simple Air Ride question that I have not seen the answer to
I'm considering an airride system in the future, possibly on Malitude. Thing is I like the adjustability of being softer for cruising and normal street driving (I'm old! ) and then being able to step up for a track day. But doesn't any air pressure change also give you a ride height change? So if you get the car setup for the track at a particular pressure wouldn't the height and alignment be off when you adjusted it for the street setting?
I'm not looking for a ride height change as much as a handling and ride comfort change. I like the ride height Mark did with this car. It's plenty low for me and nothing bottoms out or rubs. Ideally for me the height would not change (or very little) but you could soften the car up for cruising and still set it up for track use on the same alignment. Do they have a system that does this?
