Old 01-02-2017, 09:40 PM
desids's Avatar
desids desids is offline
Just catching up on your build - that color is just amazing. Nice choice.
Old 01-03-2017, 08:43 AM
DT69Cam DT69Cam is offline
Which gas pedal do you use ??
https://lateral-g.net/forums/atta...1&d=1386130537
69 Camaro Convertible (LS3/TKO in the works)
Old 01-04-2017, 08:03 PM
JMitch19's Avatar
JMitch19 JMitch19 is offline
Originally Posted by DT69Cam View Post
It's a C6 Corvette pedal.
Jason Mitchell
1971 Camaro 416 LT1 Project
Old 01-05-2017, 06:29 AM
Thank you very much. It looks like a 1st Gen Camaro pedal. I thought the Corvette pedals where smaller, guess I was wrong. Thanks again.
Found a pic of the pedal I was thinking Of: http://www.jegs.com/images/photos/80...9-10379038.jpg
Old 01-05-2017, 06:38 AM
JMitch19's Avatar
No problem. The only reason I knew was because I wired it up. This is the pedal we used.
http://m.ebay.com/itm/05-13-Corvette...734?nav=SEARCH
Jason Mitchell
Old 01-05-2017, 08:43 AM
Thank you again! Do you know if the GMPP harness will plug into that pedal ? I like that pedal better than the one that comes with the GMPP harness kit.
Old 01-06-2017, 08:00 PM
JMitch19's Avatar
I would assume so. If you have a schematic for the gmpp harness I could check for you.
Jason Mitchell
Old 01-07-2017, 07:10 AM
Unfortunately all I have is the manual:
http://www.chevrolet.com/content/dam...d-19259293.pdf
Old 01-07-2017, 10:21 AM
JMitch19's Avatar
The ECM is pinned the same as a factory LSA engine. I'd assume the throttle pedal would be no different.
Jason Mitchell
Old 01-07-2017, 05:07 PM
Thanks!!!
