Old 03-03-2020, 07:28 PM
cjfirstgen's Avatar
cjfirstgen cjfirstgen is offline
Talk about trying to make 10lbs of s#%t fit in a 5 gal bucket and try to make it look good. Accusump, oil thermostat, remote oil filter mount w/ primer, cooler, radiator overflow, PS reservoir and cooler, ProVent 200 separator, trans cooler and diff cooler. Holy cow! Went all in with Fragola Race-Rite Pro PTFE hose. Invested in the hydraulic crimper, etc and the hose is seriously light weight which has always been a consideration on this build. The hose is awesome if you are considering it but sure is pricey. The bend radius without collapse is very impressive.
Anyhow one corner just mockup thus far.
Project "Mercury Rising" '69 Camaro : https://lateral-g.net/forums/showthread.php4?t=41460
The Following 2 Users Say Thank You to cjfirstgen For This Useful Post:
Goosesdad (03-24-2020), syborg tt (09-06-2020)
  #292
Old 03-05-2020, 11:43 AM
Dave Pratt's Avatar
Dave Pratt Dave Pratt is offline
Wow that looks great I've been thinking about getting a hydraulic crimper and those hoses to replace every hose in my engine bay.Looks great what you've done...
Old 03-24-2020, 08:19 AM
cjfirstgen's Avatar
The dash layout for the Motec C1212 - street and track versions.
The Following 5 Users Say Thank You to cjfirstgen For This Useful Post:
cpd004 (02-07-2021), Goosesdad (03-24-2020), Jay Hilliard (05-24-2021), syborg tt (09-06-2020), WILWAXU (03-25-2020)
  #294
Old 03-24-2020, 10:06 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Sweet gauge layout. I like it...
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 03-24-2020, 02:47 PM
WOW! That is sweet! I love it. What are the dimensions?
Old 03-24-2020, 05:03 PM
cjfirstgen's Avatar
Thanks!
12" diagonal or 11.5" x 4.25"
Old 08-10-2020, 01:17 PM
cjfirstgen's Avatar
Haven't posted in a awhile but things are progressing well. Plumbing is done which was a total PITA. Coolers, required SB4 vent with 1" lines and Accusump made it challenging to route while minimizing appearance. Electrical is basically done. Had a minor setback with the T56 mag trans where the cooler pump fitting would not seal. I bought the trans used on a 1 year old Tranzilla build so take no chances I sent the trans to Texas Drivetrain Perf and had them repair the issue. Also went with some Liberty Gear billet interlocks, new bronze fork pads and swapped out 6th gear for .58 vs .67 from the 2:29 ZR1 gearset since I will be running 3.73 or 3.90 gears. Should keep a nice 2200 rpm range on the highway for cruising.
We just started hanging the front sheet metal and finishing up the dash.
fleetus macmullitz (08-10-2020), syborg tt (09-06-2020)
  #298
Old 08-10-2020, 01:24 PM
cjfirstgen's Avatar
Sound system is basically done. Just a small 8" sub for just a bit of good bass. Using Memphis Audio. Wires are not fully tucked but you get the idea.
https://www.memphiscaraudio.com/prod...ss-source-unit
Since everything is controlled with the Ipad thru the InfinityBox InTouch unit I wanted something discreet to control volume and advance a song selection separate from an app. ^^^^ This Memphis unit was perfect so just a small switch that we will incorporate into the interior center console.
The Following User Says Thank You to cjfirstgen For This Useful Post:
  #299
Old 08-10-2020, 01:27 PM
cjfirstgen's Avatar
Coming together.
Dash preview....no visible switches other than the start button. Switches that we have are hidden in the ashtray. The wiper switch is mounted under the dash.
camcojb (08-10-2020), syborg tt (09-06-2020)
  #300
Old 08-10-2020, 01:35 PM
camcojb camcojb is offline
