Old 03-07-2014, 11:41 PM
frankv11's Avatar
frankv11 frankv11 is offline
A lot of work getting done , nice going on that steering colum.
Like the steering wheel
Old 03-08-2014, 10:16 PM
Definitely some talent there. Nice job.
Old 03-08-2014, 10:53 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Originally Posted by MX145 View Post
Thanks guys! My dad deserves a lot of credit for the progress. We divided up the work to try get something done. It seemed like we weren't getting anywhere for a while there.
Nice work... looking good. That's great that you and your dad are working on the car together. Keep it coming
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 03-09-2014, 09:27 PM
MX145 MX145 is offline
Thanks guys!
Old 03-09-2014, 09:37 PM
I test fit the glass and top dash. The dash fit well enough to install the windshield but I decided to work it some more to get it where I wanted it.
Things line up better and have a more consistent depth with the glass now. I can't wait to get to the point of installing it. The car strangely seemed more complete with it mocked up.
Old 03-09-2014, 09:53 PM
We wanted to maintain the collapsable feature of the column along with taking advantage of the telescoping and tilt so we spent a good portion of the day figuring out the best way to shorten the new column and how to make a cover sleeve that would taper down and fit behind the NRG hub. My dad milled down the column tube factory upper mount locations and modified the 68 upper mount so it would bolt together and to the dash the same as the factory. The internal shaft is a 2 piece double D collapsable design so I drilled out the injection molded pins to move up a few inches for new plastic pins.
My dad didn't like the factory open area for the shift tube on the steering box side of the column so he cut the outer tube and re-cut the notches for the bottom bearing and retainer. Looks much cleaner and won't allow dirt to get inside so easily.
I'm hoping to get it assembled and painted in the next couple weeks. Working on the car one day a week isn't enough.
Old 03-09-2014, 11:20 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
Looks great, Ryan! Now I wish I test fit my windshield...
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 03-19-2014, 12:23 AM
Nothing really to post from last Saturdays work. Cleaned up and primer'd some parts, mocked up the shifter, and put the car on the wood blocks for easier access. Steering column's back together today so I should be able to put that back in this weekend. Just about ready to bring it home for body work.
Old 03-19-2014, 12:32 AM
frankv11's Avatar
Looking good
Old 03-19-2014, 04:09 AM
tubbed69's Avatar
tubbed69 tubbed69 is offline
looking very good,you are doing a great job
