Old 10-23-2012, 07:40 PM
Cole Cole is offline
Banned
I agree on the taillights. They pop too much!
Old 10-23-2012, 07:46 PM
itsals1 itsals1 is offline
I'd powder coat the outer part of the housings gloss black, leave the center polished, and paint a red pin stripe on the outer raised edge of the housing!
Travis
Old 10-23-2012, 08:13 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Back tires on that car are HUGE! I like it!! Agreed...the tail lights don't fit the vibe of the car.
Curtis
Old 10-23-2012, 09:24 PM
Originally Posted by John510 View Post
Do you guys think turbos near the carbon fenders will melt my inner fenders?
Depends on how close you are and if you plan to run any heat shields. The basic answer is yes - you will see damage from heat. Once the surface temp exceeds the cure temp of the resin in the panel - it will soften and then the resin will begin to boil off leaving dry fabric. If the temp gets to close/high you will set the resin on fire. You'll need to use protective wraps or heat shields of some type.
If the original cure of the panel was at room temp, or cured at high temp, or post cured at high temp will tell you what the temp operating range you should protect th surface from.
Jim
My Project: 65 Porsche 356G
https://lateral-g.net/forums/showthread.php4?t=5109
Old 10-23-2012, 09:50 PM
It looks great John.
Old 10-23-2012, 11:04 PM
Vince@Meanstreets's Avatar
you can always get the tail lights coated translucent black.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 10-23-2012, 11:58 PM
Swain's Avatar
Swain Swain is offline
John. Who makes those tail lights? I bought EMS ones that I'll be milling down a bit around the edges to give a little cleaner look
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 10-24-2012, 12:03 AM
John510's Avatar
John510 John510 is offline
They are Fesler lights.
[SIGPIC][/SIGPIC]
Old 10-24-2012, 12:42 AM
skatinjay27's Avatar
add another one to the list of "dump the lights"
they stick out like a sore thump... i prefer the look of the marquez lights myself, not just for finish reasons but they are much more detailed and aesthetically pleasing.
AJ
Old 10-24-2012, 01:44 AM
Amituk's Avatar
Amituk Amituk is offline
Defo agree.. those lights are too much.
I would go for some anodised black ones myself.
Re the carbon, you should be fine. Consider F1 cars that are made of carbon and the exhaust run through the bodywork.
but worst case, fab up an stainless heat shield?
Build thread -NightHawk - 69 Camaro supercar build
Facebook -Like ProjectNighthawk
Twitter -@ProjNighthawk
