Old 08-14-2019, 06:34 PM
formula98's Avatar
formula98 formula98 is offline
That’s too funny! Looking forward to seeing it go back together...
Ron
1970 RSX Z28
The Following User Says Thank You to formula98 For This Useful Post:
syborg tt (08-15-2019)
Old 04-29-2020, 10:21 AM
syborg tt's Avatar
Found more pics similar to Nicks.
This is Buddy’s car.
marty-mj
The Following User Says Thank You to syborg tt For This Useful Post:
cpd004 (05-11-2020)
Old 04-29-2020, 07:57 PM
syborg tt's Avatar
Working on wire routing and keeping it so I can service it if needed.
Gratuitous Front End Shot. (02-25-20)
So the plan is to run a portion of wires down the rocker gutter and sneak into the inside of the rear quarter.
So if you have been in my garage you have seen my collection of twist tie's. I use these for mock up instead of zip ties as I can quickly change directions and not waste zip ties.
If you look closely you can see all the wires are twist tied together and when I add the last couple wires I can easily add them in.
Eventually these will be secured inside the quarter after I confirm everything works correctly.
Instead of using the giant factory plug I will replace all of the unions with weather pack connectors.
Time to epoxy in a few more Weld Mounts
Loom Anchored in place (02-26-20)
marty-mj
WILWAXU (04-30-2020)
Old 04-29-2020, 08:06 PM
syborg tt's Avatar
So this is one of those moments that most people don't think about or consider. (02-27-20)
With all of the new paint coating out there this is the time to have a Professional come in and do paint correction and surface
coatings. The good news for me is my neighbor is that guy and he Gonzo Details. So I asked him to come over and correct and protect
the paint before I get the front clip on the the car.
Firewall Complete.
Perfect time to surface protect and area that once the fenders and inner fenders you can't access.
Yep, he even did inside the cowl.
Subframe
marty-mj
Old 04-29-2020, 08:12 PM
syborg tt's Avatar
Workbench is looking a little thin & Building a better center channel mount. (02-29-20)
Remember these as these are really cool zip ties and apparently I forgot to take pictures of the clasp area.
Planning for the center channel (03-01-20)
marty-mj
Old 04-29-2020, 08:32 PM
syborg tt's Avatar
Valuable lessons learned in life (03-01-20)
Most people that know me are aware that I like to sit back and watch, listen, photograph so I can learn new thing and
new ways to do things. The reason I photograph everything is so I can go back and look at what I saw a 2nd, 3rd, 4th
or even a 5th time. Being honest some times I go back and look at things so much that I print them out and stick them
on the walls in my garage or my office.
After seeing my wife work on white boards for years I realized that I could get a dry erase board for the garage and plan
the wire routing that I wanted to do in this version of the car. It so much easier for me to have a visual plan versus something
in my head.
So once again out comes my Garage Desk and the dry erase board.
Honestly, I really love Blue Tape if you all haven't figured that out yet.
Once I am comfortable with the dry erase board I transfer my thoughts to the cars note pad.
At the same time I am trying to plan the new dash layout since I am going with the new 7" Holley dash and I still want to
have something that will fill the right side of the dash surround and I think this is what I am going to put in that area.
(03-05-20)
Well somewhere along the way I misplaced a couple brackets and some hardware.
Thankfully D&R Classics is only 25 minutes from my house so a Quick trip over and some Taco's and I am back to
work on the car.
I also spent a little garage time searching for intake tube idea's and I am in love with the set up the guys at
Chris Holstrom Concepts executed on there Camaro. (03-06-20)
marty-mj
Old 05-14-2020, 09:18 PM
syborg tt's Avatar
Quick update.
I finally went back and fixed all the broken image links on all posts.
It only took me a week.
marty-mj
WILWAXU (05-14-2020)
Old 05-21-2020, 07:45 PM
syborg tt's Avatar
Little bit of everything ( 04-18-20 )
So, I finally test fitted the Kicker Center Channel
Started installing all the Vintage Air Lines to make sure everything fits nicely.
Running the wires that will eventually hidden above the inner fender.
Reminders that I need to fuse this wire
Apparently Classic Dash makes a new dash insert for the new Holley Dash.
Picked up some more Chunky Bars and some wire
More parts for Pro-Tek Powder Coater
So I misplaced the hardware for the DSE Wiper Motor. So another trip to Ace Hardware.
Need to open these up a little more for DSE Truck lights.
All better now with plenty of light adjust me room.
I like reference pictures by sometimes a diagram is worth it's weight in gold.
Found a couple more parts for Pro-Tek Powder Coating
marty-mj
Old 05-21-2020, 07:58 PM
syborg tt's Avatar
The Afco LS 2nd Gen direct fit Radiator. ( 04-21-20 )
Vintage Air AC Condensor with brackets that Kenny made.
My notebook is getting a workout as it the credit card.
Just a random picture
marty-mj
Old 05-21-2020, 08:01 PM
syborg tt's Avatar
Adam from Gonzo Details is back. ( 04-22-20 )
marty-mj
