Old 06-13-2018, 01:04 PM
Ron Sutton's Avatar
It's a roller!!!
Dang, hard to say what I'm most impressed by... First probably is the backspace on the front wheels along with the overall width of them. Scrub should be most excellent it appears... Then I guess how it all looks so simple and clean yet is so over engineered and awesome at the same time.
Nice work fellas...
Ready to blow it back apart for powder coating yet?
Good eye Lance! This is a "Zero Scrub" car. So it cuts like a mutha in the tight corners.
The chassis & suspension will get powder coated ... and the body sanded & wrapped ... after our June 28th track test. Then all put back together to run the NorCal Shelby Club Mini Nats August 3-5.
Ron Sutton Race Technology
Old 06-13-2018, 01:07 PM
NOT "mini" Nats this year!! This years SONOMA IS THE NATIONALS!!!
EEEEEHHHHHAAAAAAAAAAA
Only important really to Mustang/Shelby guys --- but it will be a big Shelby event
Old 06-13-2018, 01:14 PM
jarhead's Avatar
jarhead jarhead is offline
I spy a Torino
joe
Semper Fi
My 68 Torino
Old 06-13-2018, 01:43 PM
Originally Posted by jarhead View Post
I spy a Torino
Yes! That is another Track Warrior car they are building for a customer......
Old 06-13-2018, 01:47 PM
Ron Sutton's Avatar
Okay ---- enough of the slow old guy and diaper stocks...... ITS TIME FOR AN UPDATE
Oh man! You beat me to the punch for posting photos. I have a few duplicates, but I'll post them anyway to add text.
Car Year & Model: 70 Ford Mustang Fastback
Competing in: Track Car & Occasional NASA TTU races
Front Clip/Suspension: GT Track-Warrior
Rear Clip/Suspension: GT Track-Warrior
Engine: Track-Warrior 3 LS7 700 HP
Trans: PPG Sequential Shift T56 6-Speed
Brakes: StopTech 14” ST60/ST40
Owner: Greg Weld
Builder: Randy Chastain – One Off Customs
More updates & photos ...
Most of the stuff is straight out of our "Build-Your-Own Track-Car Catalog" HERE
The RSRT Track-Warrior 3 LS7 built by SDPC Race Shop - Details HERE
PPG Sequential T56 6-speed Trans, built by Joe Dederichs - Details HERE
QuarterMaster Optimum RR Clutch with 2 "Rally" Discs for easier take off - Details HERE
A shot today before Body was removed ... to get an idea of tire width & track width.
Wheels are 18x13 Forgeline GZ3R. 10" backspacing in front.
This is a "Zero Scrub" car. Turns like a mutha in the tight corners.
Good look at the wheels, Track-Star hubs & StopTech Trophy brakes Optimized by Ron Sutton
Front End mount photos
Door Hinges
With Body Removed to finish the door X-brace bars
Car is Super low to ground, as you can see.
In fairness, this fella is 6' 1" / Actual roof height is 47"
The Following User Says Thank You to Ron Sutton For This Useful Post:
jeds (06-13-2018)
  #306
Old 06-13-2018, 01:54 PM
Ron Sutton's Avatar
Oh! Not "mini" this year. Well okie dokie then.
Your car will have Shelby tail lights. Does that count ?
Old 06-13-2018, 02:08 PM
jeds jeds is offline
I noticed that a lot of your engine packages state that you use are using a cable operated throttle body.
What drives the decision to use DBW or cable? Availability of throttle body size for power considerations? User preference? Other?
Old 06-13-2018, 03:07 PM
57hemicuda's Avatar
57hemicuda 57hemicuda is offline
Car looks awesome in the go cart form, but that transmission.....yummm
Ron Schwarz
The Following User Says Thank You to 57hemicuda For This Useful Post:
Ron Sutton (06-13-2018)
  #309
Old 06-13-2018, 03:22 PM
Ron Sutton's Avatar
Howdy !
Actually ... I need to change that in our new catalog ... because we offer both DBW-Drive by Wire and traditional cable operated throttle bodies. It is user preference (or needs). I find we sell about half cable operated & half DBW. Just depends on what the end user needs.
For the DBW throttle bodies we use:
* Stock GM LS3 92mm version for 625HP & lower
* Nick Williams 102mm version 700HP & up
For the Cable operated throttle bodies we use:
* Holley 90mm for for 625HP & lower
* Holley 95mm for for 675HP & lower
* Holley 105mm for for 700HP & up
For Greg's car, the electronic "no-lift" sequential shift controller needs a DBW throttle body to work correctly. On upshifts, the electronic "no-lift" sequential shift controller kills the power for a fraction of a second, to make the shift smooth. But the throttle stays wide open (as long as the driver has the throttle pedal wide open.) On downshifts, the electronic "no-lift" sequential shift controller needs to "blip" the throttle to make the downshift happen smoothly, so a DBW throttle body is needed.
If we had not ran the sequential shift transmission, we would have ran a cable operated throttle body.
Hope this insight helps.
DBasher (06-13-2018)
  #310
Old 06-13-2018, 06:59 PM
57hemicuda's Avatar
Picture reminds me a little of my Mustang back in 2007........only racier. Man I love build pics
Ron Schwarz
