Old 08-02-2015, 09:38 PM
zj510's Avatar
zj510 zj510 is offline
The raptor looks killer you said you reduced the u pol raptor 15% what did you use to reduce it with?
Old 08-03-2015, 06:09 AM
Payton King's Avatar
That was funny Skip!
Old 11-28-2015, 12:07 AM
MX145 MX145 is offline
Awesome pics at Camarillo. Car looks great Ron!
Old 11-28-2015, 11:57 AM
Ron in SoCal's Avatar
Thanks Ryan!
Ron in SoCal
69 Camaro in progress
Old 11-28-2015, 01:05 PM
The car sounds awesome in the video!
What did you end up doing on the fuel vent? I broke down and bought a II Much as I can't see any other good way to vent these cars. Looks like I'm going to do the same on the rear end. Packaging is tight so I'm trying to find a rollover check valve that will work with the vent mounted in the DSE crossmember. I found a jaz 6 an inline valve that I thought would work but it's upside down. I need opposite male female.
Old 11-28-2015, 02:04 PM
Thank you Sir
Car is a kick in the pants. Little more rear grip and little more brake and I think it'll do fine. Course, the wingnut still has a long was to go
Fuel vent has a temp fix via a rerouted line. I need to get it on the lift and bend up some tube which I hope will be permanent. If I didn't mention before, my II Much vent is mounted in near the tail panel which is not correct. Your way Ryan on the crossmember / highest point is best.
Ron in SoCal
Old 11-28-2015, 02:25 PM
randy randy is offline
Finch dual vent system works great. Route one line to the tank and another to the diff. I put my box on the dse quadralink trunk brace
Old 11-28-2015, 03:56 PM
Your video got my blood pumping. You have a lot more horsepower than I do. You must be smoother on the throttle and definitely a better driver. I'm also running Michelin PS's and am hoping to mount up something better suited for the track next year. I need all the help I can get to stay close to the cones and keep the car pointed the right direction!
I ran some temp vents for fuel and diff in order to pass tech so it's time to do something permanent. The II Much vent is nice quality I just need to find a roll-over check valve that will work. I'm trying to keep everything up high and avoid creating a "p" trap in the vent line. Maybe I'm overthinking it.
Randy, I didn't even know those were out there. Does the Finch vent to the outside like the II Much does?
Old 11-28-2015, 05:54 PM
Yes. It's a darn nice box.
Run a line to the tank to the diff to the box using -6 an fittings, a line from the diff to the box using the same -6 an fittings. If memory serves me correct I used the following..... 4 -6an female to hose fittings on each end of the hose, 2 hoses about 14" long, 1/4" npt male to -6 female for the tank and 1/8" npt male to -6 female. 2 fittings for the box that are 1/4" npt male to -6 male
Www.finchperformance.com
Old 11-28-2015, 06:41 PM
Thanks Randy. I'm going to look into the Finch option some more. Rollover check valve and outside vent are my requirements.
Sorry Ron. Didn't mean to hijack your thread. I appreciate the info from you both.
