Old 07-14-2012, 07:42 AM
Leadfoot1's Avatar
Leadfoot1 Leadfoot1 is offline
WoW!!! Thats a lot of work!!
Im just thinking...did you ever tought about an acid bath or something? Followed by electrodeposit primer or the like? I saw that done a few times and to take care of all the rust like you seem to be wanting to do it might have been the ticket!! Not sure it would have come that expensive, and it would have covered every spec of rust!! I consider myself a little asking on quality work but when it comes to getting to EVERY little spot...Man, it just never can be done. You really seem to want to get every inch done so i wonder if that system crossed your mind or not.
Great job so far! Keep it up! You are one patient dude!
Lead.
LEADFOOT1
New for summer '13. My latest find!!
48k miles, 100% original, 1969 Camaro coupe. Untouched, never apart and squeaky clean!!! 327/th350, A/C car. Gold on black w/vinyl top. Only add ons; Fast ratio box and SS396 wheels.
FINALLY!!! A car without rust repairs ever!!! None before, none coming!!! Cant come to modifying it tough....
...So, '67 Camaro project with my laying around stuff out of my black 'vert. 468 BB and YSI blower, braked th400, 12 bolt/spool, 35 splines etc. Complete Calvert suspension front and rear. 30x13.5 ET Streets, caged, lightened, slammed and running low 9's "Street car"
Old 07-14-2012, 10:43 AM
Sonar Chief's Avatar
Smile
Originally Posted by Steve68 View Post
Time for the handheld sand blaster,and clean that up,
Sand blasting won't get underneath where the rust started , so the roof has got to come off .... to do it right
Lead.
Thanks ... have your read Stielow's book? The neutralizer after the acid dip didn't get into the same spots as the acid and the doors rusted out requiring redo on the doors.
I may be getting all the rust off the car the hard way, but .... I didn't introduce any chemicals, sand or any media that didn't come from the factory and I know it's done right.
Thanks for asking thou ...
Old 07-14-2012, 10:45 AM
Black93GT's Avatar
Black93GT Black93GT is offline
when i was pulling my quarters out I found rust in the drip rails the same as yours. it was rusted inside the seam. the spot welds didn't exist anymore. I ended up grabbing my plasma and cutting the roof off.... only to find the drip rail panel itself was rusted nearly the entire lenght. oh well... what's one more panel at this point.
Old 07-14-2012, 11:01 AM
Thumbs up Sprayed exopy
primer on the door jambs, sills and the rocker panels Had to get up at o dark thirty, actually around 0630 and get the car wiped off and get going before the garage got too hot.
Came out alright ... had a couple runs no biggy thou, now I can hang the doors and get the other parts set in place and outa my boys bedroom.
I didn't mask off anything off .... a grey scotch brite will take care of the over spray (the floor will get epoxy and then Lizard skin anyway). There will be more high fill primer coming later so no biggy.
Door jamb done.
Check.
Time to hang the doors
Jambs came out nice!
Got the inner and outer rocker to the pinch weld
So a good day so far, everything is drying and I'm outa epoxy, I knew I didn't have enough for the quarters .... nice timing. Time for some inside stuff during the heat of the day.
Thanks for looking ...
Old 07-14-2012, 11:04 AM
That is why you gotta take the panel off and see what's under the rust .... I am getting everything else done first and then I'll tackle the roof .... it's holding the car together now and I don't wanna cut too much off the car at once.
Thanks for sharing ...
Old 07-21-2012, 09:40 PM
Thumbs up 7/21 Update
It's a good day when parts come in, been gone all week and my AMD side cowls are here ... so now I can finish the cowl and the firewall!
Man do they fit 110% better than those other (China made) ones, so I had to fit them and see what the car looks like with side cowls ( I forgot) I am glad the AMD parts fit, should have ordered them from the beginning ... I now know there is an AMD dealer here in town that will get all my business fer sure.
The driver's side cowl doesn't quite have the same curvature as the upper cowl piece, but that is not a deal breaker just means I have to work with it .... BFH
I was working with the stripping gel today on my inner fender wells and let's just say when it's 100 out there is NO SUCH THING AS GEL It turned to liquid so I let it dry and scrapped it with the wire brush and most of the paint came off, I'll work on them early before it gets too hot again !!!!!!
Gel turned to liquid with the heat
Driver's side cowl fitment ... it's better than the other ones.
Passenger side fit was almost perfect
I'll get going before the sun heats up the garage and I have to come inside and take a nap
Thanks for looking ....
Old 07-21-2012, 10:09 PM
Its looking good!
Old 07-22-2012, 11:51 AM
Thumbs up Sunday 7/22
Got some time in the garage before it got really hot. Since I have the side cowls now I patched the OEM blower hole and worked on the inner fenders.
Found some rust between the panel on the inners .... guess I'll have to do surgery and fix that before I epoxy.
Patching the blower hole
Quick test fit.
GRRRRRRRRR rust between the metal.
I'll have to fix this pretty soon!
I really would like to get ANVIL inner fenders but ... that's alot of coin, so I'll fix what I have and keep plugging away.
Maybe I'll get back out in the garage after it cools off ... now it's NAP TIME
Old 07-22-2012, 11:53 AM
Thumbs up
Its looking good!
Thanks .... it's getting there
Old 07-22-2012, 06:13 PM
Thumbs up This is why
sandblasting doesn't get ALL the rust! This is my inner fender that was sandblasted in 2002 and painted with epoxy primer and replaced on the car.
As you can see the areas that were sandblasted and epoxied are fine but .... the rust continued from between the panels
So I drilled out the spot welds and cleaned everything and I will put some POR15 on the areas tomorrow when I can get the time for two coats and the final black. Then I'll weld her up and all is good with this one, the other one needs a patch fabricated and the same steps to stop the rust.
Lesson learned ... do it right the first time.
