Old 07-06-2013, 06:32 PM
Stielow's Avatar
Stielow Stielow is offline
Guys a couple updates. I had my car together at my car party so a couple shots of the car.
Mark
Old 07-06-2013, 06:43 PM
Stielow's Avatar
We have the Cooling "stack" in the car and the ECM and BCM mounted.
I have learned put the ECM and BCM (Fuse Block) where you can get to them easy.
Start of the inlet tube. It will flare from 4" to 4 3/4"
Mark
Old 07-06-2013, 06:49 PM
tubbed69's Avatar
tubbed69 tubbed69 is offline
Mark great work as always,sure has a nice stance
Old 07-06-2013, 06:51 PM
Flash68's Avatar
Flash68 Flash68 is offline
Wider tires and stance look killer.
Do you know the front and rear new track width by chance Mark?
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 07-06-2013, 07:03 PM
fleet's Avatar
fleet fleet is offline
Mark,
It appears lower than some of your other Camaros.
Is it, or will it be?
Old 07-06-2013, 07:11 PM
Sieg's Avatar
Sieg Sieg is offline
Really like the front bodywork, the styling below the headlights is very clean, including the fender to lower cowl junction.
Have you designed a bumper bar behind the carbon yet? Alloy or CM?
Good Work Mr. Stielow
Old 07-06-2013, 07:13 PM
DaleTx's Avatar
DaleTx DaleTx is offline
Looks great Mark... I am wondering how much weight savings with the carbon fiber parts on the front.
Look forward to more pictures on the build and info on the dry sump system install. The front spoiler looks great!
"If you wait, all that happens is you get older"
Mario Andretti
69 Camaro-Nutter Racing Engines/427CI LS2 sleeved/LS7 CNC ported heads/Custom cam/T&D 1.8 rockers/Manley crank/Manley H-beam rods/Weisco pistons/NRC Pro Series dry sump/Kooks/NA,92 octane,11.5:1- 672HP @ 6,900RPM, 566TQ @ 5,500RPM
Build Thread- http://ls1tech.com/forums/generation...ine-build.html
Old 07-06-2013, 07:14 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
All of that carbon fiber looks awesome. As already stated, stance is spot on too.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 07-06-2013, 07:28 PM
Stielow's Avatar
Originally Posted by compos mentis View Post
Mark,
We slammed it down for the car party. Not sure if we will run it that low. It is about an inch lower than Red Devil.
Old 07-06-2013, 07:32 PM
Stielow's Avatar
We will build a bumper stiffener made out of CM. It also need to reinforce the lower grill support.
Mark
