Old 11-21-2013, 08:04 AM
captainofiron's Avatar
captainofiron captainofiron is offline
Originally Posted by Tuske427 View Post
Thanks, Wayne!
Today, with 3 trips to the hardware store, I was able to finally get my tank installed. I keep ruining the stainless steel tank strap carriage bolts. They just bind up and break when trying to remove the nuts. Very frustrating. I also built a few flexible fuel lines with some goodies that arrived from Summit Racing. I ordered the PTFE lines and put a few sections together and connected them to the tank, as well as made a few of the front brake lines and installed my master cylinder. Between using the copper nickel alloy and the Eastwood brake flaring tool these were a breeze to make. Let's just hope they don't leak. I also tacked on a few brackets to the rear axle for mounting brake lines before I ran out of daylight.
stainless steel on stainless steel is a recipe for galling usually
a little bit of anti seize will help fix that
Old 11-22-2013, 05:26 PM
Tuske427's Avatar
Tuske427 Tuske427 is offline
(slap to the forehead) I wish I had known that and I have a bottle of anti seize, too... Thank you for the tip!
Long Live the Muscle Car
https://lateral-g.net/forums/showthread.php4?t=26338
Instagram: @tuske427
Old 11-24-2013, 09:25 PM
Tuske427's Avatar
Well, I got the engine in this weekend. Cool
To do that I tied down the front brake line along the crossmember, assembled the flywheel/ clutch/ throwout bearing and bolted & torqued the trans to the engine, then learned that I should measure the throwout bearing so it came back apart. Seems I'm within spec (barely) and shouldn't need a shim for the throwout bearing. Since I was on a roll I set the engine in the car on Sat night. I did gouge a few areas and scrape some paint. Oh well, I plan to drive the car, not trailer it to shows. I also mocked up the fuel line and installed the fuel pressure regulator and cut the hole for the shifter. I have the original bracket from the old trans tunnel that I'll weld back in for support. I have a few more parts on order and hope to get a little more done over the holiday weekend.
Old 11-25-2013, 05:22 AM
streetbird's Avatar
streetbird streetbird is offline
good idea to paint the ls green pontiac.
I had the same idea for mine, but im not at the same point in my built
The French Frog
Old 11-25-2013, 08:07 AM
Ron in SoCal's Avatar
Big step Brendon. Congrats!
Ron in SoCal
69 Camaro in progress
Old 11-25-2013, 10:36 AM
Congrats Brandon; That's some great progress. It looks good in there.
Old 11-25-2013, 08:04 PM
Tuske427's Avatar
Thanks, guys! Ron- you'll be glad to know I put that alum flywheel to good use. It's in there...
Old 11-25-2013, 09:48 PM
FETorino's Avatar
FETorino FETorino is offline
Congratulations that is a big step forward.
Rob in SoCal
Old 11-26-2013, 04:17 PM
LS7 Z/28 LS7 Z/28 is offline
Nice progress, looks great!
Old 11-28-2013, 08:03 PM
MX145 MX145 is offline
Ditto!!
