Old 09-27-2015, 07:56 PM
It was so much fun to run with you and Paulette on GG Hall of Fame! Can't thank enough for your help with my A/C issue... Didn't think I'd ever have to "hot wire" an A/C unit! LOL
Love the Don Hardy Race Engines built LS3 in the '33.... not a single drop of oil... not a leak... fires up and ready to go regardless of how hard we drove them.
Come to think of it -- I think it was 4 of us pretty much leading the pack for the tour -- and we all had LS motors! WTF - we even had a LS powered '49 Caddy on the tour!
XOXO
Old 09-28-2015, 05:55 AM
kwhizz's Avatar
kwhizz kwhizz is offline
XOXO
Yep..........Can't wait till next year !!!!!!.........I'll be starting a couple of new threads for the new projects in the Garage soon !!.......
Ken Greg......As you know......It get's expensive hanging with Charley....LOL
Old 09-29-2015, 06:16 PM
kwhizz's Avatar
Originally Posted by Boss 5.0 View Post
Awesome build! I enjoyed reading all the way through. I have a 66 Chevelle as well and I have a couple questions for you pertaining to the suspension.
On the rear coil overs, what pound rating did you go with? I have 150# springs and I'm thinking I should have 200 in the rear.
And, could you give me a measurement for both front and rear from the ground to the top center of the wheel openings? Just one of each is fine. I love the stance on yours, trying to compare yours to mine, curious how close. Wouldn't mind getting my rear down a little, but if I do the top of the rear just bumps the floor if I hit a good dip in the road. I think without notching the floor I'm at my limit.
Hope that isn't too much trouble for you?
Thanks,
Glenn
Don't remember what the spring rate was......Standard Ridetech as supplied in their kit.............Height.......24" front and 24 1/4" rear........Hope that helps
Ken
Old 10-02-2015, 02:33 PM
Boss 5.0's Avatar
Boss 5.0 Boss 5.0 is offline
Ken
Hmmmm......
That is where I want my rear to be, but mine is at 25 3/4". I have a 29" tall rear tire, and with the QA1's that I have I can't see how to get it lower.
Did you notch the floor at all above the rear end? If I were to drop mine lower it would hit the floor where the two upper control mounts are on top of the pumpkin. Right now I only have maybe two inches of clearance. The floors in my car are absolute virgin perfect, I don;t want to be the one to cut them after all these years.
Thanks for the time to measure for me. Much appreciated.
Copper Hill Rod & Custom
1955 Chevy BelAir
1951 Chevy 3100
1987 Chevy R10
Glenn
Old 10-02-2015, 05:06 PM
kwhizz's Avatar
Didn't cut anything........I'll take some pic's tomorrow.....
Ken
Old 08-31-2022, 04:05 PM
kwhizz's Avatar
Update....... Didn't drive the car much this year, been driving the Impala all over..... Took the Chevelle out last week for a local show..... the car ran perfect as usual... On the way home after getting off the highway I noticed the engine was running rough...... Humm!!!!..... I was 10 minutes from home so when I got the car in the garage (no check engine light) I plugged the scanner in and no codes....... Hummm!!!!!......Used the infared heat gun and shot all the Header pipes...... #3 cyl was showing no heat....... Humm !!!!....... Put a spare coil on and started it up .......Same thing......Pulled the spark plug and it looked O.K........ Checked for spark and everything good......Hummm!!!!!......Got Air....Got Spark..... Fuel????...put a Noid light on the plug on injector #3 and everything good....... Hummm !!!!...... The only thing that made any sense was that the injector went bad (36,000 miles)....... Ordered a new set and put them in and the car run's perfect again......... You never know...... LOL
The Following 4 Users Say Thank You to kwhizz For This Useful Post:
camcojb (08-31-2022), Ketzer (09-01-2022), Roscoe03 (09-02-2022), waynieZ (08-31-2022)
  #357
Old 08-31-2022, 06:59 PM
camcojb camcojb is offline
Thanks for the update Ken. Not a really common occurrence I would think, injectors generally last a lot longer than that. Appreciate you posting up the steps to determine what had failed.
kwhizz (09-01-2022)
  #358
Old 09-03-2022, 08:55 AM
sru1436 sru1436 is offline
Awesome car and build, I went through the entire thread. What radiator manufacturer and fan set up did you use. I’m in the process of replacing the radiator and fan set up on my 66? Thanks.
Old 09-05-2022, 09:03 AM
kwhizz's Avatar
Griffin assy.............
Ken
The Following 2 Users Say Thank You to kwhizz For This Useful Post:
camcojb (09-05-2022), sru1436 (09-05-2022)
