Old 06-16-2024, 10:13 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Originally Posted by NOVA View Post
The GM O.E look is Perfect
Yes it is!! Saves a lot of money too.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 06-17-2024, 04:59 AM
Frankenstine's Avatar
Frankenstine Frankenstine is online now
Default UNDER HOOD BOLTS
GREAT UPDATE PICKS MR STIELOW, CAMARO IS LOOKING GREAT
THE STOCK LOOKING BOLTS UNDER THE HOOD LOOK GREAT. DID YOU USE A MASTER BOLT KIT? IF SO CAN YOU TELL THE MANUFACTURER YOU USED ??? IM LOOKING FOR NEW BOLTS FOR MY PROJECT.
Old 06-18-2024, 07:38 AM
F'in mine's Avatar
F'in mine F'in mine is offline
If you're looking for factory fastener hardware check with this company.
https://www.amkproducts.com/master-k...fastener-kits/
1969 Camaro SSRS
Simon
Old 06-19-2024, 02:22 PM
Stielow's Avatar
Stielow Stielow is offline
We took all the stock 1969 bolts and had the stripped and zinc plated. A place in Mai will do is for fairly cheap money.
We strip and plate a lot of parts. Easy maintenance and they look great.
Stielow Engineering
Old 06-20-2024, 05:47 AM
Stielow's Avatar
In the past I had to get SKF to custom make me wheel bearings with the “ZR1” style bearings. MPI make a “Big Bearing” that had the larger two row ball bearing, the bigger ZR1 splined internals and passive wheel speed sensors.
For people not attempting to use 2008 and older Corvette ABS this is not an issue. If you are like me, then these are perfect and cheaper then the SKF “Big Bearing”.
https://www.mechanicalpower.net/shop...-hub-assembly/
Mark
Stielow Engineering
Old 06-25-2024, 03:24 PM
Stielow's Avatar
Stielow Engineering
The Following User Says Thank You to Stielow For This Useful Post:
fleet (09-10-2025)
  #357
Old 06-25-2024, 10:17 PM
fleet's Avatar
fleet fleet is offline
Wow Mark, that ‘factory fresh’ underhood look is so clean!
Old 06-28-2024, 06:52 AM
Stielow's Avatar
Stielow Engineering
fleet (09-10-2025)
  #359
Old 06-28-2024, 12:47 PM
NAPA 68 NAPA 68 is offline
Love the project, although for selfish reasons I hate to see it coming to the end.
It always seems like you have had another core car stuffed in the bushes waiting to go. Any chance?
Not that your day job commands a little time.........
Old 06-28-2024, 08:08 PM
Stielow's Avatar
Well we will be starting Camaro XX soon.
Stielow Engineering
The Following 2 Users Say Thank You to Stielow For This Useful Post:
fleet (09-10-2025), srode1 (10-08-2024)
