Old 07-23-2011, 12:35 PM
Jr's Avatar
Jr Jr is offline
No big deal. I'm getting ready to try and fit my factory ac (ls conversion) in the stock location on my 70 c10.
Old 07-23-2011, 04:04 PM
ScotI ScotI is offline
They don't fit very well down by the frame w/o cutting. I was looking @ this one when planning the swap for a 6.0 I bought. They show 'truck/2010 camaro' as one option so they might be very close....
http://www.kwikperf.com/lsx_ac.html
Old 07-29-2011, 02:47 PM
Cris@JCG's Avatar
Cris@JCG Cris@JCG is offline
Default Stainless Tanks
So, we were about to start fabricating covers for the front inner wells to radiator support & got this idea that will kill two birds with one stone..
How about a coolant over flow tank & power steering tank out of stainless with a few machined pcs... Working on mount brackets right now.. will post a pic later of it mounted..
One thing I have learned about plumbing & making custom tanks.. is make tanks.. Wait till you have everything mounted & pre-run lines before you weld mounting bungs to tanks..
Cris Gonzalez
Old 07-29-2011, 03:49 PM
70rs's Avatar
70rs 70rs is offline
The cool parts just keep rolling out from your shop.........
Eric
Old 07-29-2011, 04:16 PM
coolwelder62's Avatar
Cris,How do you keep the tank's from leaking with only tack weld's. Are they welded on the inside.
Old 07-29-2011, 04:45 PM
Rick D's Avatar
Rick D Rick D is offline
Cris how are you ever going to finish this car when you keep coming up such cool new parts. Outstanding as always
Rick
Old 07-29-2011, 05:52 PM
Cris@JCG's Avatar
Thanks Eric! I just can't help myself
JB Weld! Common Scott.. Like you have never used it before!
Thank you! But I got to stop .. I need to have the engine compertment wrapped up by late next week.. I need to give up the car for a few days to the uphostery shop..
Here is the mock of what things will be looking like.. I gave myself enough room to run A/C lines thru the bottom.. We need to build a bulk to retain all fittings..
Here is an idea of what the pass side plumbing came out like.. the fuel lines are done, oil filler tube is on the firewall, oil breather can is plumbed..
Got some mock up prototype pcs on the driver side.. If not I would give you a full shot of the engine bay..
Cris Gonzalez
Old 07-30-2011, 11:52 AM
67turbostang's Avatar
67turbostang 67turbostang is offline
Great work as usual!!!
Old 08-03-2011, 04:39 PM
Cris@JCG's Avatar
Little update!
Cris Gonzalez
Old 08-03-2011, 04:43 PM
Not too Bad.Not too Bad.
