The car is back up on the jack stands…. propane heater fired up… and I’m ready to work on the winter upgrades!
I have been reading a lot of posts on here recently about safety for pro-touring cars, and the new street car events coming up in 2014 (USCA & ASCS). I have been contemplating what direction to go with my car in terms of “safety features”. Both USCA & ASCS are currently working to define the classes, and rules for their street car events. After reading lots of posts about this I have made a decision of how to set up my car.
My car will be
purpose built “pro-touring style”, to allow me to drive comfortably on the street (around town, or on long trips)... and to drive on road courses at HPDE events in my area (PIR, The Ridge Motorsports Park, and ORP). I want to drive on the street, and hang out with my friends at the track. I have the most fun with my car when I’m on the track. It’s fun to go fast on a closed course and see what the car will do (legally) in a safe environment. The direction I'm going is to build a multi-purpose car and make it as safe as possible for both types of driving.
Currently my car has upgraded brakes; chassis mods; solid body bushings; sub-frame connectors; driveline loop; fabricated tubular a-arms; front and rear sway bars; modified suspension; 4 point roll bar; Sparco seats with side bolsters; 5 point seat belts; and on board fire extinguisher.
Here is my plan for this winters upgrades:
Personal safety equipment to purchase:
Driver suit.
Gloves.
Shoes.
Helmet set up with Hans, or similar type device.
Upgrades to chassis/brakes:
New front spindles with higher strength, and higher load rated bearings.
Install ducting to help cool front brakes.
Add removable door bar tubes that attach to the 4-point roll bar.
Upgrades to engine and trans:
Modify front drive to prevent the serpentine belt from rolling off the pulleys and taking out the dry sump pump belt (this happened last summer!).
Replace timing gears and chain to new Cloyes LS Z-Racing set up.
Replace GM ZR1 LS9 hydraulic throw-out bearing with Katech HD Tilton unit.
Also… I will inspect critical parts, and check bolt tightness on a regular basis… and limit my top speed to 135 mph (in my car that’s 6,700 RPM in 4th gear). I have noticed when I get over 135 MPH the aerodynamics become an issue. Up to 135 MPH the car is stable, and rock solid... so 135 mph will be my own personal speed limit (plenty fast to have fun!). At some point I could do aero upgrades... but not now.
On to the winter upgrades.
Right before the SEMA show this year... I went for a drive and my throw-out bearing started making a loud squealing sound when I pushed the clutch in. Yesterday I pulled the trans to check it out.
This is what I found
I was pretty disappointed to see the $300 ZR1 OEM throw-out bearing fail after only one season of use! I called Jason at Katech and he said they never used to have a problem with these bearings… but recently have seen several fail. He said something changed with the OEM supplier and he suspects the grease melts out, overheats the bearing, and melts the plastic slider (I would be curious if Carl C. or others, have input on the bearing failure). My bearing fell apart when I pulled it out (balls fell out on the ground)… the slider was melted… and the bearing appeared to be very dry (no grease). Jason said he has seen this scenario before with guys that track their cars.
The fix
Since I bought my ZR1 twin disc clutch kit from Katech (2 years ago)... they have come up with a heavy duty hydraulic throw-out bearing setup that fits the T56 transmission. The new HD set up is recommended for guys tracking their cars. This bearing has no spring, and only contacts the clutch forks when the clutch is pushed in. The slider is aluminum instead of plastic... and the bearing is a heavy duty sealed bearing.
Pics of the new throw-out bearing set up
New bearing height is the same as the OEM unit
I didn't think I would be pulling the trans again so soon. Driving on the track is hard on things. I'll just keep working towards making the car as bulletproof as possible.
Thanks to Ron S. and the other guys on here for all the great discussion on safety!
