Old 03-24-2016, 07:00 AM
mdprovee's Avatar
mdprovee mdprovee is offline
Looking good and getting close.
Mike
Old 03-25-2016, 02:56 PM
WSSix WSSix is online now
No worries, Mike, lol. It's your car anyway. I think it looks good.
I found this powder coat after seeing the red translucent wheels posted in the wheel gallery
http://www.columbiacoatings.com/stor...cent-TGIC.aspx
I ordered a pound of it to do my aluminum dash panel. I think it will turn out nice. You might find that it will give you the look you're after, too. You don't have to do a silver or chrome coating first if you're putting it on a bright metal base. You could also take their suggestion and try a different base color/coat all together and create a unique look.
Old 03-26-2016, 10:28 AM
Ron in SoCal's Avatar
not sure, josh knows though. specs are.595 intake .605 exhaust, 281/287 duration 112 lobe sep. by Comp Cam,
Yikes!
Originally Posted by cjsgarage View Post
The black wheels really do look good on there.
the cam is a 233/239 @ .050", lift is 595"/605", on a 112 degree lobe separation
^ that's more like it. Wheels look great!
Ron in SoCal
69 Camaro in progress
Old 03-26-2016, 10:24 PM
glassman's Avatar
glassman glassman is offline
Originally Posted by Ron in SoCal View Post
Yikes!
Ha, read the wrong part of the cam card. Thanx for the thumbs
Mike
Old 04-07-2016, 02:28 PM
cjsgarage cjsgarage is offline
Yikes!
that is advertised duration. I just don't think anyone pays attention to those numbers.
I like wiring. No joke.
Old 04-11-2016, 02:06 AM
Back to where we left on on the build part of the build thread:
Mike installed the front accessories and I got to working on the wiring harness. Mike had installed the dash harness and the lighting harnesses front and rear. It got everything measured up so I could cut out what we weren't going to use and plan out the additions like the fuel injection system, computer, vintage air and stereo head unit/amplifier.
Dash harness initial
Replacing the old with new
Adding relays for the electric fan and the fuel pump
and a completed piece
Old 04-11-2016, 02:13 AM
Those stringy bits in the middle are how the VHX by Dakota Digital wants to be plugged in. If I were to do it again, I think I would make a connector and make it disconnectable.
So the dash harness gets me to about here:
Then I took off the radiator support and started on the front lighting harness
and I'll skip to the good part. Here's the lighting harness done and laid on the engine:
Old 04-11-2016, 02:23 AM
I prefer the ultra cleanest install I can get. and I've never liked how the wipers came out of the engine side of the bulkhead. I always thought it would be a whole lot easier to disconnect the engine as a whole from the bulkhead. Besides that, Mike is considering doing a remote mount wiper since the firewall smooth sheet he made required a wiper delete. So I moved the wipers over to the lighting side.
Speaking of ultra clean.. Here's what I did with the rear lighting harness. I included the fuel pump wiring and the stereo amplifier wiring and the gas gauge wiring right into the same harness. One harness disconnects the entire rear of the car. Nice.
The former fuel sending unit ground was ran through the roof of the car.
So here's the leg bone being connected to the hip bone again.. the entire interior had to come out (less carpet) for the new lines to be run and the old to be removed. There were powers and ground running down the passenger side for the vintage air and speaker wires.
Old 04-11-2016, 02:27 AM
Engine harness pre assembly:
And here's partially through assembly:
Old 04-11-2016, 02:32 AM
Here's a little section I had to redo because the sheathing wasn't long enough and pulled out the shrink:
Here's what it looked like before it was finished:
Lastly, I had to wait for a special tool to come in so I could finish the MilSpec connector that makes the engine truly disconnectable in a few seconds.
Here's the mating side of the connector and where it plugs into the ECM and the dash harness
