Old 12-10-2007, 08:29 PM
As for which frame I honestly believe if the two frames were run in the same car, same driver, same track, same weather, same humidity.............well you get the point, that when the dust settled neither would have a sizeable advantage over the other.
It has been said a few times, what the hell, I will be the parrot! Do you like the Corvette aluminum / fabricated stuff, or more modified factory / OEM look. Not often is the final decision for suspension components all about looks, but this could be the exception. The rear suspension really has no bearing on the final subframe decision in this case.
Some people like to keep the car all with one manufactures products, others like to mix it up
Frank Serafine
gearhead1186's Avatar
gearhead1186 gearhead1186 is offline
Originally Posted by ProdigyCustoms
Soon as I saw your post this evening I called also since that is WAY under distributor pricing by HUNDREDS of dollars. I got the same thing but when I tried to pay it was rejected.
So the guy told you that you can apply the discount at first but then when he asked for credit card info something happened?? When I called I didnt try to pay, I just asked if the discount would apply and he said yes.
Old 12-10-2007, 08:33 PM
this is more of a long term build as I dont have the funds to make a 6500 purchase at once... with that said AM seems like the one for me.. I can buy the bare clip, I like the fabricated look and you cant go wrong with vette aluminum. it will always be there.. thanks a bunch
Old 12-10-2007, 08:47 PM
We have to verify it in the morning.
Frank Serafine
Old 12-11-2007, 12:08 PM
let me know when you find out.. thanks
