Old 02-24-2008, 07:26 PM
01somta 01somta is offline
Default Project "Rubbed Raw" 68 Camaro
Here is my original thread that I start about a month ago. I started a new thread because I now have a name for the car. My finger tips are rubbed raw from all the grinding, sanding, and scrubbing trying to get the liner off my hands.
https://lateral-g.net/forums/showthread.php4?t=12975
I have since taken everything off to be powdercoated, so I though it would be a perfect time to coat my undercarriage. Then entire process of undercoating took alot longer than I had expected, I worked on it about 12 hrs both Sat. and Sun. I first cleaned up all the welds from the floor pan swap, primed, seam sealer (Lord Fusor), prep wipe, sanded, tacky cloth, and then coating (U-Pol Raptor Liner) . It took me longer to clean my dang hands then anything else, I have used hand cleaner, gas, mineral spirits, and just about anything else and they are still coated. Here are some pics.
Materials
Up on engine hoists
Before anything
Old 02-24-2008, 07:27 PM
Taped off, primered, and sealer
Old 02-24-2008, 07:29 PM
Close up of texture
Finished
I will have my hands full when I get my subframe, rearend, and four-link parts back from powder coating
Old 02-24-2008, 07:56 PM
TravisB TravisB is offline
I really like the texture of that liner.....did you do it yourself? What did you spray it with? how much overspray did you have? how many coats is that?
ok im done with questions now....ha ha
looks really nice by the way
Kenny Davis Hot Rods
Old 02-24-2008, 08:14 PM
no pictures of the hands?
1/12th scale 1969 Sunset Orange Metallic Camaro Pro Touring Style>>
Progress Thread
Artwork Page
Old 02-24-2008, 08:16 PM
I thought about it, but they were too nasty to touch the camera.
Old 02-24-2008, 08:15 PM
Yes, I sprayed it myself with a average compressor @ 55psi, overspray was very controlable, that is only one coat. It kind of looks like it has some spots that need more coating in the pictures, but it is just the flash on the wet coating.
Old 03-21-2008, 03:13 PM
awr68's Avatar
awr68 awr68 is offline
Originally Posted by 01somta View Post
Finished
What are the two square tubes hanging down from the x-member, sway bar mounts? Trying to figure out it out...
Tony
'68 Camaro
Old 03-21-2008, 05:19 PM
Fuel cell mounting bars with studs, the fuel sits up in the trunk pan. I didn't want the cell inside the trunk pan or hanging down real low.
Old 03-21-2008, 05:21 PM
here is a pic standing back looking at it. I am going to trim the studs a little bit more (1" or so) once everything is back in.
