View Poll Results: Which rear suspension?
DSE's Quadra Link 104 45.61%
Alstons G Bar 77 33.77%
Leave the GW Cat 5's 17 7.46%
Just pull the trigger go Lateral Dynamics 30 13.16%
Voters: 228. You may not vote on this poll
Old 11-14-2008, 09:32 AM
Can we Add torque Arm to the Poll?
I am on the fence on one side is the G Link on the other a Torque arm. I would be interested in see the TA added to the mix
Old 11-14-2008, 02:08 PM
Marcus SC&C's Avatar
Marcus SC&C Marcus SC&C is offline
As mentioned the G Bar and G Link both work great with existing mini tub kits.
There is a Mopar E body G-Bar. While it doesn`t offer all of the adjustability of the G-Link it can be run with an adj. rate rear swaybar and is an impressive performer in it`s own right.
Torque arm systems can work quite well. Their overall format precludes them from having much antisquat and limits instant center location and SVSA length though which can make them one trick ponys. They can still hook hard in a straight line but it general requires the rest of the car to have a more hardcore drag set up than a comparable adj. 4 link car to run the same short times. These are generalizations of course but it`s one reason they aren`t more popular. One nice thing about them is it`s almost hard to build a bad one where it`s very easy to build a crappy 4 link, just ask the OEs... Mark SC&C
Old 11-16-2008, 06:18 PM
zerotofear's Avatar
zerotofear zerotofear is offline
Our background is in the stockcar industry, I am a big fan of truckarms, two long torque arms that use the weight of the car to create forward bite. A trackbar is used as locating device, and adjusted up or down to control body roll, forward bite, and effective sping rate. This rear suspension is extremely simple, affordable, versatile, but more than anything it is the most competition proven system availible.
We use full floater rears as you see the truck arms are mounted solid to the rear.
The truck arms angle back from a center crossmember to the rear end.
The coil-overs are mounted on this car infront of the rearend
We have mounted a D-M Products Rear anti-roll bar on this car for drag racing challenges.
The quick clips allow us to disconnect the rear bar for road courses.
The crossmember has adjustable slugs left and right and these can be used to align or mis-align the rear depending on the handling characteristic you want.
Old 11-16-2008, 10:34 PM
mazspeed's Avatar
mazspeed mazspeed is offline
The G link is much better in the performance aspect. DSE is the way to go if you can swing it.
I drove a camaro about 18 moths ago with a truck arm rear from Hotrods to hell, and it was the biggest POS. It rode fine but it's not a performance rear by any means.
Old 11-16-2008, 11:26 PM
skatinjay27's Avatar
truck arms rear suspension is not the same as a tq arm. 3rd and 4th gens use tq arm setups. its a tq arm from the tranny crossmember to the rear and uses a panhard to keep the rear center and uses two lower contol arms like typical 4 links.
AJ
Old 11-17-2008, 05:49 AM
zerotofear's Avatar
Not a performance rear? This system has won as many races in the USA as any other system, even the fact that it is almost boob proof some boobs can screw up anything. Truck arms are in fact are torque arms solidly mounted in the rear the arms transfer energy by absorbing the initial shock under acceleration, under most systems this shock is transfered to the tires causing tire spin. Under braking the arms transfer the braking torque into the chassis pulling the car downward to the track.
www.smokinss.info
Old 11-17-2008, 07:25 AM
Lateral-g Moderator
DSE 4 link.
Old 11-17-2008, 10:11 AM
Silver69Camaro Silver69Camaro is offline
Morrison 3-link direct-fit rear clip. But I'm biased
Seriously though, a three link that allows you to keep your rear seat AND greatly improves torsional stiffness. Or a proven triangulated 4-bar that requires no floorpan cutting. Easier to install than a set of reproduction rear frame rails. Definetely an option to consider...
http://www.artmorrison.com/gallery/v...maro-FrontClip
Matt Jones
Mechanical Engineer
Art Morrison Enterprises
Old 11-17-2008, 10:31 AM
mazspeed's Avatar
Yes very true. I don't know much about the tq arm though.
Old 11-17-2008, 10:01 PM
z4me69 z4me69 is offline
went through the same decision between the g bar and q link . am lucky enough to have a couple of friends with both set ups. i went with dse hands down the best thing i ever did to my car
