Originally Posted by Steve1968LS2
That's a good idea if you are using an air based cooler. But, if you're running one through the radiator they it's unnessary since the water will warm the oil in addition to cooling it.
Not so.
On cool days the oil temperature in mine during normal cruise the oil temps get to maybe 150*. On the freeway, 140*. If I hammer it for a while, 180*. On warm days it will get up to over 200* occasionally.
I would really like the oil temp to be 210-220* during normal operation, so a thermostat is in the planning stages. I may go with a Mocal, but the CV part is really nice.
No matter how much heat turbos may add to the oil, if the oil is overheating a cooler is needed. Worst case the cooler will delay the onset of overheating, but the amount of oil a turbo uses is much smaller than that used in the rest of the engine, which creates a lot of waste heat during high-horsepower output.
