Old 07-23-2009, 08:40 AM
Ron Fox's Avatar
Ron Fox Ron Fox is offline
Default Orange Peel
Is it possible to remove ALL the orange peel out of a paint job?
Thanks,
Ron
1969 Firebird, 4-speed Coupe
[email protected]
Old 07-23-2009, 12:20 PM
GM Muscle's Avatar
as long as theres enough clear on the car it is.. a hard foam block and some 1200 grit, then 1500, then 2000-2500. wool pad with compound then foam pad with machine glaze.. maybe a little swirel remover and you should be golden..you can alternate your strokes to make sure you have knocked out the heavier grits.. like do your 1200 from lower left to upper right then the 1500 in an alternate direction, then the 2000 in a different.. this would come in handy if you were doing the entire car..
'69 Camaro- Daily Driver
'70 Chevelle- Project
Old 07-23-2009, 02:36 PM
Ron Fox's Avatar
Hi GM,
I am not a painter or even a builder like most in here. I am have my '69 Firebird built from the ground up with mods. The person who will be painting my car (not in the near future) says it is difficult to get all orange peel out to where it is smooth as glass. He says it could be done but it would take may hours to do.
I have noticed on a car he painted recently that at the end of the car is where orange peel is noticed. Why is this? Is it because this is where the paint stops or overlaps going back the other way?
Thank you for your help.
Ron
1969 Firebird, 4-speed, Coupe
[email protected]
Old 07-23-2009, 03:02 PM
GM Muscle's Avatar
it is definately a long tiring process. it is probably where the painter started, went around the car and finished. he probably should use a hotter a reducer so the paint stays wetter long enough for him to get around the car. *sometimes*, and its very rare, i have sprayed straight reducer(very hot reducer) or blender directly over the "rough" if im done spraying and notice anything. it will probably haze or fuzz but i would much rather knock off a little haze than deal with orange peel
another thing i have noticed is that if you have a car with a mirror finish like that, it is extremely easy to notice swirls and scratches..
Old 07-26-2009, 07:45 PM
Ron Fox's Avatar
So does the paint dry and while going over the same area a second time causes orange peel? Or is orange peel too much paint in one area?
I am a rookie/non-gear head when it comes to building cars and thats why someone else is building my car. So the past several years I have been reading, watching car tv shows, going to car events, and talking to every gearhead I run into trying to learn all the pros and cons of building a car. It took my close to 2 years to find a builder I could trust and who has the knowledge to build a car with honesty and details.
All the info is greatly appreciated.
Ron
Old 07-26-2009, 09:44 PM
Don't forget to add a bit of soap to your sanding water bucket!! That helps keep your paper unclogged....
Old 07-27-2009, 06:17 AM
Orange peel is generally caused by incorrect spray gun setup, incorrect material mixing, or the most common (not enough practice!) Spraying paint/clear is easy making it lay down like glass is an art!
Orange peel can be removed with 1500 grit sand paper on a firm block (if there is enough clear). Factory paint jobs are 1.5 coats thick and generally not enough to sand out the orange peel and polish. Now the cottage cheese/fat lady leg (bigger uneven waves in the panel) that you see is from the filler/primers under the base. You need to have each level of the process as straight as possible starting with the metal, fillers, and primers.
Jeff Allen
J2 Speed and Custom
Old 08-01-2009, 02:46 PM
214Chevy's Avatar
214Chevy 214Chevy is offline
To simply answer your question .......YES!!!
**Spend a little money on a paint job...expect orange peel.
**Spend an arm & a leg on a paint job..get no orange peel(hopefully).
I've seen $25k paint jobs without a flaw on them. Me personally, I can't afford that so I'm fine with my $6k paint job without almost no orange peel. Only I notice it because it's mine and I know where it is. And other paint guys notice it because that's their job. But the average Joe looking at my car thinks it's the best damn paint job he's ever seen.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
