Old 04-23-2011, 07:23 PM
68protouring454's Avatar
ty is going to have both transmissions in his cars. He has talked about both synchronized transmissions and face plated dog ring transmissions in his posts
t-56's hold up plenty well with good syncros and steel shift forks and a few other goodies, we have had one in a time trial car for 3-4 years and its just getting tired, and its behind a 686hp, 580 tq 427ls
we run that to 7200-7400, gear changes are precise.
are you not sure what you will be doing, you mention road race and street use in the same sentence?
Liberty can face plate/dog ring 1-4 and leave 5 and 6th synchronized, which just may be the ticket for your hi revving engine.
Jake's Rod Shop
Old 04-25-2011, 05:25 PM
Croaker's Avatar
Croaker Croaker is offline
For the record, the Keisler R&T T-56 ty was referring to is designed to be shifted clutchless. It goes without saying you wouldn't want to attempt that with a transmission with traditional synchros.
http://www.keislerauto.com/recent-ne...k-6-speed.html
Old 04-25-2011, 06:05 PM
exactly
Jake's Rod Shop
Old 05-04-2011, 11:52 PM
tyoneal's Avatar
tyoneal tyoneal is offline
Originally Posted by funcars View Post
Somehow the question about 6 spds changed to dog ring 4 spds and how some choose to use them. I was hoping (like the OP) to get some more info on high rpm shifting capability, accuracy of gear changes and durability for a 6 spd road race application that uses syncros and is more street capable.
I also prefer to change brake rotors and pads instead of trannies and clutches.
I also have a ZF6 in my c4 corvette track only car and it shifts very nicely but I only use it up to about 6500 rpms. They are just too big to fit in a 70 Mustang trans tunnel, need too much work to adapt and cost a fortune to rebuild.
Anyway - for high rpm use with syncros what works well? I have a POS Richmond 5-spd that needs to go in the trash and want something that works well with a 600 hp 7800 rpm dry sump motor on the road courses. No drag racing is in it's future.
funcars:
Sorry it took a while to get back to you on this. Here (I hope) are the things that will help answer your questions.
Here is the information on the Transmission:
Take a look at the 6 pages here that speak about the transmission. I think it will answer a lot of your questions. This transmission can be used on the street with a clutch or without. The only time a clutch HAS to be used is for launching the car, or stopping.
Take a look at this and let me know what you think based on your background. By the way, I appreciate your comments and input.
Thanks,
Ty O'Neal
Project, "EnGULFed"
1964 Gulf Liveried, Corvette, "Grand Sport"
Ty O'Neal
"She Devil" aka. Betty
1969/70 Camaro SS
427 LS3, 600
Keisler Road and Track T-56
Full size 3 link and custom roll cage
315mm tires on rear, should fit the same on front. Worked to design a more effective shape.
"Chester's '65"
1965 Buick Riviera
Aiming for true PT Status with
the best available from the 70's and 80's
Old 05-17-2011, 09:00 PM
funcars funcars is offline
Ty,
Thanks for the info. Maybe a face-plated trans is something to consider - as long as there isn't too much routine maintenance.
1970 Mach I 380 Dry Sump + lots of mods
1990 C4 Corvette 400 in solid roller
1965 Corvette - back to life some day
1970 1/2 Z28 project car
Old 05-23-2011, 04:20 AM
tyoneal's Avatar
Ty,
Funcars:
At least according to Shafi, these transmissions are supposedly pretty tough.
I had originally bought it for the Camaro, but I'm going to stick it in the Grand Sport for now (Since it will be done first) and get the hang of it. I should be at a point with the Camaro sometime next year, (Hopefully) where I can pull it from the Corvette and replace it with a T-56 Magnum. Then run the hell out of it in the Camaro.
I'm going to start a thread and see if any other people on this forum have been using it.
Take care,
Ty
Project, "EnGULFed"
Ty O'Neal
1969/70 Camaro SS
427 LS3, 600
"Chester's '65"
1965 Buick Riviera
