I've been trying to figure out what ball joints work with that spindle.
The LBJ taper depends upon the steering arm used. They have two different variations, one is for the full size GM ball joint, the other is for a Mopar style BJ. They also offer ball joint "sleeves" so you can make or modify your ownlower control arms (uppers too, for that matter).
When Den gets his Impy hubs, it will be a good idea to compare the wheel mounting difference with their big ole' aluminum hub (like the one shown in the pic with the AMG brakes) that has an integral rotor mount. Also a good thing to see if the hub od (where it fits into the wheel register) is too big for a typical wheel, my guess is that Den's approach to modifying a stock hub will be far less painful for most folks going this direction.
By the way, if you are really 'core, Coleman will sell you just the pin, you can make your own spindle. But, if you aren't an ME and pro fabricator, I'd pass, this is a HIGHLY stressed suspension piece. Go get 'em Den, I am really interested in how the geometry works out.
Mark
