Old 10-24-2011, 04:17 PM
R.A.D's Avatar
R.A.D R.A.D is offline
now your pickin' uo steam keep rollin'
LIKE THE MAN SAID "EYE BALL IT"
http://fordodgetrucksonly.forumotion.com/
RIDESBYDESIGN.COM
Old 01-23-2012, 04:49 PM
wedged wedged is offline
I had some time available this past weekend. I got the heim joints for the rear upper air ride shocks a few weeks ago. now they won't bind and split the bushings.
started working on installing the Wilwood proportioning valve. The stainless line are tough to double flare.
Old 08-20-2012, 05:45 PM
last weekend I bent up some cunifer brake line for the front end and measured for hoses. Messed with the hoses today to check for clearance and fit. It's looking good, lock to lock and full retracted and extended suspension.
Now I need to get a rivet nut setting tool so i can fab and attach brackets.
right lock, extended
left lock extended
left lock compressed
right lock compressed
Old 11-11-2012, 01:14 PM
The stainless steel gas tank did not fit flush to the floor pan and the filler neck would not line up with the hole in the rear body panel. The main problem is that there was no notch for the trunk pan reinforcement rib. I cut a notch. That got the holes much closer to being aligned and the tank will now sit flush against the trunk pan. I may need to cut out the filler hole and move it up some too. I've never welded stainless before so this is an adventure. I also never cut up a $600 gas tank before either
Old 11-11-2012, 10:14 PM
Vince@Meanstreets's Avatar
check with Greg Weld before you start. He gives great pointers. Like leave an open hole and drop a few pieces of dry ice inside the tank.
BTW is that a Ricks tank?
Great looking project!!
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 12-13-2012, 08:43 AM
I don't recall where the tank came from, but they didn't take into account why the factory tank has a recess in that spot. It's a similar situation to the bushings in the rear shocks splitting just from the suspension being cycled by the lift going up and down.
Old 09-01-2013, 10:14 AM
The ac condenser, trans cooler and radiator support got painted flat black. The radiator core will also be painted flat black to match.
Old 01-03-2015, 01:53 PM
