Old 03-28-2011, 04:19 PM
bonecrrusher's Avatar
bonecrrusher bonecrrusher is offline
Whats the spec on that rear tire?
325 or 345 width?
2005 LeMans Blue Corvette w/ T56 & Z51 & C6Z06 Brakes, Build Thread: https://lateral-g.net/forums/showthread.php4?t=27408
2005 GMC Sierra 2500HD - LLY - Allison
2014 Chevy SS - LS3 / 4 Doors
Old 03-28-2011, 05:09 PM
James OLC's Avatar
They are 325/30-19s on the back.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 03-28-2011, 07:15 PM
Ron in SoCal's Avatar
Goodyears? C'mon James, give it up...
Ron in SoCal
69 Camaro in progress
Old 03-28-2011, 07:50 PM
James OLC's Avatar
Yep... Z06 spec Goodyear Eagle F1 Supercar G:2 run flats.
James
1969 Camaro - Dusty
Old 03-28-2011, 08:29 PM
I heard that's good for at least 3/10 @ Spring Mountain...could be just bench racing, tho
Ron in SoCal
Old 03-29-2011, 03:51 PM
Ah cool - I'll be running the same tires on my Vette - since I was stranded 700 miles from home with an awesome flat!
Car is looking great!
Old 04-07-2011, 08:23 PM
James OLC's Avatar
RIP clutch
"Died in the Line of Duty"
2011 Del Mar, CA
Editor's Challenge Autocross
Carnage pics...
The outer disk looked bad...
but the floater disk had some pretty colors...
but was not as flat as it once had been...
warped just a little bit...
which took it's toll on the inner disk...
but now its on it's way back together...
James
1969 Camaro - Dusty
Old 04-07-2011, 08:26 PM
James --
At least it died a honorable death in the line of duty!
Old 04-07-2011, 09:11 PM
Question for you James - I just happened to see the year old Camaro Performers article of your car and noticed you were running the RST. With the power you're making and the way you flog the beast, was there any thought to going with the RXT this time around? It's supposed to be a little beefier...
Ron in SoCal
Old 04-07-2011, 09:54 PM
The WidowMaker's Avatar
and its more forgiving. i was told that due to the material differences, you can actually burn the rxt up a "little" and it will fix itself once some material gets removed. do that to an rst and its a resurface job.
im interested to see how well you like it. ive heard nothing but good reviews.
"The WidowMaker"
