Old 12-01-2014, 09:35 AM
Chassisworks Chassisworks is offline
Supporting Vendor
Originally Posted by Moose View Post
So this is over a year old. I'm debating right now on which tubs to buy. Chris Alston come with close out panels, I'm not a awesome fab guy, but OK. I like that I can get everything in one stop. But DSE have been around for so long..
Chassisworks has been around since 1987, in case you were wondering, but Chris original company was building drag and Can-Arm cars as far back as the 70s.
Here's a link to a good install article of our tubs on a 69 floor pan from Super Chevy - http://www.superchevy.com/how-to/pai...eating-floors/
Here's the set going in Steve Rupp's Track Rat '68 - http://www.superchevy.com/how-to/pro...-tubs-install/
And LSXTV's Project Blank Slate '69 - http://www.lsxtv.com/tech-stories/br...l-over-system/ Side Note: they didn't read/fully read the g-Link install directions which state that the frame brackets are to be stitch welded.
Old 12-01-2014, 05:50 PM
Moose Moose is offline
ok Carl you touched on to something here I was thinking about. I have the G-bar set up on my camaro. I had a shop weld it up. I'm assuming I'm going to have to cut some of that back and re weld it.
second, How do I get around the lower control arms not hitting the tires..
I'm going to read all of those articles.
Old 12-01-2014, 10:01 PM
califconstruct's Avatar
califconstruct califconstruct is offline
Default Installed
A little feedback from the install.. It all went well, Rich didn't experience any problems during installation, (other than running out of Bud Lite).
Fitment was good, close out panels fit well.
Overall tubs seemed as good as DSE, and vise versa. This is the second car of mine that I mini-tubbed and the parts were both well made.
Chassisworks
DSE
Old 12-02-2014, 02:06 AM
Rick D's Avatar
Rick D Rick D is offline
Just a question are the DSE and Chassisworks the same size?? I thought the Chassisworks were not as wide?? Not sure that's why I'm asking?
Rick
Old 12-02-2014, 07:30 AM
im4u2nvss im4u2nvss is offline
Does the Chassisworks kit now include closeouts that fit the 67?
Old 12-02-2014, 04:21 PM
Supporting Vendor
ok Carl you touched on to something here I was thinking about. I have the G-bar set up on my Camaro. I had a shop weld it up. I'm assuming I'm going to have to cut some of that back and re weld it.
Second, How do I get around the lower control arms not hitting the tires..
Are you talking about installing the mini-tub and modifying the bracket on the frame rail? You should just be able to cut it back then stitch weld the new edge together.
Clearance with the lower control arm, on the current version, is increased if you order the offset pivots. CLICK "IMAGES" TAB AT LINK HERE.
They have always fit the '67. There are additional cutouts that we now include which will ONLY be used if you have a '67 non-staggered-shock car.
I like this pic!
Chassisworks
Old 12-02-2014, 06:00 PM
rocketrod rocketrod is offline
I was wondering the same thing.
Rod
1969 Camaro - LS2/4L70E
Old 12-02-2014, 06:40 PM
Vortech404 Vortech404 is offline
I am pretty sure both tubs are 2.75" bigger than stock.
John
Old 12-03-2014, 06:40 AM
Carl,
My g-bar is at least 4 years old and looks different from your link. Can I call you directly?
Old 12-03-2014, 09:08 AM
Supporting Vendor
I can confirm that ours are 2.75" wider than stock.
Carl,
Yeah, my extension is 247. I'll probably have you email me a pic so we can be on the same page.
