Old 06-10-2012, 08:02 AM
ChuckDriver's Avatar
ChuckDriver ChuckDriver is offline
Another cool project!
JJ
My 1957 project:
http://67-72chevytrucks.com/vboard/s...d.php?t=334552
Old 06-22-2012, 06:41 AM
HOLOHAN'S HOT ROD SHOP's Avatar
HOLOHAN'S HOT ROD SHOP HOLOHAN'S HOT ROD SHOP is offline
Default deck lid fitment
Old 06-22-2012, 07:28 AM
syborg tt's Avatar
Post
Looks great Dan
marty-mj
Old 06-22-2012, 08:25 AM
4cefed 4cefed is offline
Curious on the use of what looks to be silicon bronze filler. Any particular reason over the use of er70s filler, or just a personal preference because of less heat input/ease of metal finishing?
Old 06-22-2012, 09:24 AM
Ketzer's Avatar
Ketzer Ketzer is offline
I've noticed a few fabricators using it also. I asked a friend of mine and he gave the same reasons you quoted, less heat to get flowing and easy to work after. He said your not supposed to use it in any stress/load area though...
Jeff-
Old 06-22-2012, 10:19 AM
Default silican bronze
Yeah, low heat, thin metal and rust metal friendly, and easy to grind. I use it in these applications and on any overlapped low stress areas.
I started using the silican bronze growing up in my Dad's Commercial/Industrial sheet metal shop. Used it alot in fabricating roof flashing's, rain caps, etc. Except I used a copper jacketed carbon stick, stuck in a electrode holder instead of a Tig torch.
It's also used alot in ductwork applications in nuke plants.
Old 06-22-2012, 01:12 PM
CornHusker4Life's Avatar
CornHusker4Life CornHusker4Life is offline
You make it look and sound so easy. BEAUTIFIUL METAL WORK. Or should I say ART?
Old 06-22-2012, 01:56 PM
Raitsa's Avatar
Raitsa Raitsa is offline
I am learning new tricks by reading this awesome thread, thanks Holohan
Old 06-23-2012, 07:46 AM
MoparCar MoparCar is offline
Dan,
Are you just using standard silicon bronze rod like what you would use with a gas welding set up or is it a certain alloy or size? I too grew up using it for bodywork, but that was still back in the day of gas welding and dipping the rod in flux, etc.
I sure appreciate you posting your work.
Thanks-Wes
Old 06-29-2012, 08:16 AM
Default rear bumper work........
