Old 04-24-2012, 09:49 AM
FETorino's Avatar
FETorino FETorino is offline
Something has to break first. I think I'll run a 1310 u joint as a warning light
Rob in SoCal
Old 04-24-2012, 10:20 AM
I plan on heading back out to the strip later this year. Hoping to get this thing to hook better so I'll likely take it to the limit for pro touring. If it breaks, I'll be proud.
Old 04-24-2012, 10:55 AM
6D9 Matt's Avatar
6D9 Matt 6D9 Matt is offline
Originally Posted by John510 View Post
Your T56 would snap before you broke a trutrac and axle.
33 would be fine if you want the extra safety. Just trying to save you some $$$
It has a T56 magnum in it right now... but hey, never know.
Also from what I remember, Moser didnt have 33-spline in the 9" rear application. Im not saying its not overkill, I just dont want to have to worry.
Everyones opinion is going to be different about it, hence why they are opinions. But I have talked to a few people around here that have broke 31-spline True Trac applications, and a lot less with the 9". So said screw it and the beefed up 9" is my route...
'69 Camaro
416ci / T56 / 9"
Turbo in the works...
Old 04-24-2012, 10:13 PM
Greg from Aus's Avatar
Greg from Aus Greg from Aus is offline
Well I like over overkill, so Ive got the 35 Wave Track and a Rockland T56 Magnum Tranzilla, so hopefully I will be just fine.
Greg
Old 04-24-2012, 11:26 PM
FETorino's Avatar
Greg
Have you had the wavetrac on the track? When I started the thread I was hoping to get some feedback from anyone running each piece. A few guys with Trutacs on the road courses have chimed in. What about the wavetrac any roadrace or autocross time on it?
Rob in SoCal
Old 04-24-2012, 11:27 PM
No sorry mine is still in build.
Greg
Old 04-25-2012, 12:12 PM
6D9 Matt's Avatar
Greg
VERY nice!
'69 Camaro
416ci / T56 / 9"
Old 04-26-2012, 12:34 PM
66SuperSport's Avatar
66SuperSport 66SuperSport is offline
Have the 31 spline set up in my car and fragged a TruTrac diff. last year at a GoodGuys autocross. Put in a Wave and the car now seems to rotate much better on tight slow speed corners. Awesome warranty too.
Chris Jacobs
Special Thanks to:
D&Z Customs, Roadster Shop, Weld Racing Wheels, Wilwood, BF Goodrich, Dynatech, and C&R Radiators
Old 04-26-2012, 08:36 PM
Good info Chris. Did you change anything else at the same time?
Old 04-26-2012, 09:18 PM
No other changes. The gear was fine so it was just reinstalled too.
The car seemed to want to push a little, but when we switched the diff. that completely went away. It's possible the TruTrac was messed up and that it was not releasing properly causing the push too. Maybe that's why it popped. It's much better now though.
Chris Jacobs
Special Thanks to:
