Just curious what's the turbine setup on those turbos, if you don't mind sharing? I'm running similar turbos, mine are DBB with P-trim .70 A/R turbine sides, wondering how they compare to yours.......
These Guys Are Right.tec 3 60-2 Wheel Thats One Of The Tricks That Keep These Things Alive Is The Ignition.i've Run The Other Systems And While They All Have Plus's And -'s The One Thing I've Noticed Is That The Main Bearings And Rod Bearings Look Much Better Running The Kind Of Power We Make With This Set-up.i'm Not Sure What It Is ,i Feel Its A More Stable Ignition Circuit.that Would Be My Guess.
