Old 01-09-2013, 11:02 PM
usa-69z usa-69z is offline
I have been now reading a ton of threads on the installs and problems with all ther different setups.. g-bar -ridetech, g-link-alston , dse-quadralink ,, and im finding reports of chassis cracks , and mainly ride height adjustment.. this is where im at a loss.. it seems most guys cant get low enuf without comprimising the spring length? has any systems rectified these issues yet? I believe dse have the 'lowest' setup but more cost/work for an install.. my car sits low and i dont want to lose the stance it now has..and want an 'easy' install.. street driven only ,
did anyone figure this out?
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 01-10-2013, 05:38 AM
Supporting Vendor
Is this low enough?
How about this one?
Both these use 5.2" stroke rear shocks for full travel and articulation.
If you want really low you'll need air.
Skunk Werks
Ridetech
www.ridetech.com
Old 01-10-2013, 07:29 AM
i would need to get lower than this.. is there a shorter shock on the market that will work? If i went air what other parts are added to the cost? does it become expensive i guess is what im asking
Old 01-10-2013, 08:54 AM
garymac69's Avatar
garymac69 garymac69 is offline
Are you wishing to go a lot lower height than my '69? I could adjust the rear lower (looks like close to 1/2 inch of lowering is possible), but I have 275's on the front and can't go much lower without the front tire rubbing the top of the fender at full lock. Thus I'm limited on the rear height to keep an even stance. At some point I might try some neg. camber on the front and see if I can lower the front some more. But I think it looks pretty good as is and I have enough clearance under the chassis to clear road obstacles.
Gary
'69 Camaro - 427 SBC 526hp,593 ft-lbs, Tremec TKO, Ridetech Coilover Suspension w/TruTurn, Billet-Specialties Draft 18x9, 18x12, BFG KDW 275/335
Old 01-10-2013, 09:06 AM
MCB Matt's Avatar
MCB Matt MCB Matt is offline
Originally Posted by usa-69z View Post
Ive sent them an email , and am waiting on a response ???
Did you PM or email us? PM is the best....
We can take care of you!
Matt
MCB Parts - Matt's Classic Bowties
5360 Gateway Plaza Dr.
Benicia, Ca. 94510
866-628-8746
TEXT ONLY: 925-989-9091 (Replied 8-4)
www.mcbparts.com
Email: [email protected]
Like us on Facebook for exclusive offers, info and chat: www.facebook.com/mcbparts
Hours: Monday to Friday 8am - 4pm Pacific
We ALWAYS enjoy talking to our customers!
We have a full time staff to answer ALL Questions, Tech Support or Order Status Tracking!
Old 01-10-2013, 11:54 AM
Supporting Vendor
maybe you can post up a pic of how the car is currently sitting to give us an idea of where you would like to end up?
Skunk Werks
Ridetech
www.ridetech.com
Old 01-10-2013, 03:30 PM
heres where im at now,, this is before the vaporworx tank etc
Old 01-10-2013, 05:56 PM
Supporting Vendor
Looks a lot like the red 69 to me.
You can lower the ride height of our AirBar by adjusting the coil spring down, but you will loose a little compression stroke (which is the most important as it is what keeps the car off the bumpstops).
By the looks of it you'll have no issue getting back to the ride height you have now.
Skunk Werks
Ridetech
www.ridetech.com
Old 01-11-2013, 02:26 PM
Chassisworks Chassisworks is offline
Supporting Vendor
How about this? Bret's car has our front clip and a gLink with airsprings at all four corners.
Getting your car lower than it now sits and still using coilovers is going to sacrifice a significant amount of driveability. Chevrolet decided how low your Camaro could sit in 1966. Getting a lower driving height is going to require modifying the driveshaft tunnel, floor, and frame rails. Read THIS DOCUMENT for an in depth explanation of this. It also covers the other concerns you mentioned.
On the other hand, if you want the car to sit super low, be driveable, and take it to the next level in performance we still have options. How about THIS SYSTEM?
Old 01-14-2013, 02:21 PM
wow ,, $700 to ship the ridetech rear to australia from MCB ! and $358 to ship the $350 dse tubs to Oz from dse! can anyone beat that?? this shipping is way outa the ballpark...
