Old 02-22-2013, 09:03 PM
mikels mikels is offline
Originally Posted by parsonsj View Post
In my case, it's a Sanden. I was looking for a solution that doesn't cycle the fan at max speed for 10-15s every 90s... but would run a lower fan speed for longer times. I don't know of any aftermarket fan controller that supports that, so I thought having the ECM do it would be a nice integrated feature.
That's exactly how crate engine controller will work with the pressure sensor in AC system and PWM fan control. Will modulate fan output only enough to control pressure. This is how Jackass, Red Devil, Mayhem and Camaro XV are set up.
I hate listening to a car and all you hear is the fan screaming.
Now imagine sitting in a bar listening to a conversation between Mikels and Stielow.
Ok Charlie - next time we'll use small words and speak slowly (or buy you enough margarita's you won't care). I get this same abuse from my wife and kids - now you too?
Originally Posted by Lous69 View Post
Well OK, in Rolla we did need our bars because there were no women.
I don't know what your talking about - there were tons of women in Rolla, just not many of them.
Old 02-23-2013, 06:09 AM
parsonsj parsonsj is offline
Exactly! We've got an analog input (ECT goes from 180 to 181, or refrigerant goes from 175 to 176), but a binary response: the fan goes from 0 to full speed.
How about this question: do Jackass, Red Devil, Mayhem, and XV use a trinary (or binary) switch? Let the ECM manage the fan, but the fail-safe requirement when the refrigerant gets dangerously high is still allocated to the binary/trinary switch?
John Parsons
Old 02-23-2013, 08:57 AM
clill's Avatar
clill clill is offline
I'm from the age: If it has spark and fuel it should run.
Old 02-23-2013, 09:08 AM
Lous69 Lous69 is offline
I thought we were about the same age....
This discussion "sparked" my interest, "fueled" my knowledge and I'm so full of "....." I gotta run.
Old 02-23-2013, 06:14 PM
Yes - compressor controlled by Vintage Air (including bi/trinary switch), with PWM fan controlled by ECM.
Typically fan request for AC pressure never more than 30-40% (and only that high on very high demand AC environment). At that level, can barely hear fan running.
At full tilt (90% DC for most PWM fan controllers), an 850W fan tends to make a little noise - but only see that level during track use due to ECT, IAT or oil temp. I'm ok with fan making some noise then - especially if controlling temps.
Old 02-23-2013, 08:09 PM
Excellent. I think I have a plan then. Great stuff, great discussion.
thanks!
John Parsons
Old 02-24-2013, 08:14 AM
rusty63ss's Avatar
rusty63ss rusty63ss is offline
Very interesting read!
Would this type of setup work on my C5 LS1, MarkVII, VA in my Nova? Or is my old school PCM not capable?
Thanks guys,
Dhamen
Old 02-25-2013, 07:53 AM
Thanks guys,
Dhamen
No real easy answer to your question and I'm no expert by any stretch but here is what I "Think" I have learned that may offer some insights:
So far, I have found evidence of 3 GM ECM types or series that have been used in applications that used some sort of PWM control of cooling fans and/or fan clutches as follows:
E38 ECMs have been used in C6 Corvettes and use PWM control of the cooling fan using the fan control module.
E40 ECMs have been used in some Trailblazer SS applications and use PWM control of the fan clutch.
E67 ECMs have been used in C6 ZR1s and use PWM control of cooling fan using the fan control module.
There may be more. These are just the ones I have found in my research so far.
Here are pics of these three ECM types:
E38
E40
E67
You will notice the easiest way to tell them apart is by the arrangement of connectors and fins.
I have been told the ECM itself is analgous to your desktop computer. By that, I mean within reason, each computer of the same type or series is theoretically "capable" of doing the same job as long as the right software programs are loaded into them. In other words, two computers that are made the same are only capable of running the same operating system or programs if the same software is loaded into them.
Following that logic, if one computer (or ECM) of a specific model number has the internal hardware to do a job in one application, it should be able to do it in another application provided the right software is resident inside, that software is enabled, and it is wired to the correct inputs and outputs.
So, using deductive logic, (which you should treat as suspect until you or someone who has actually done it validates or disputes it), would suggest that if your ECM is one of these types, it should be "capable" of PWM control of cooling fans because it has been used to do so in other applications.
The next challenge would be to find out if your ECM has any software inside that can be enabled to provide PWM control or if it would be possible to load that software into your ECM and then turn it on.
If all that looks possible, you would then need to figure out if you have wires in your harness for the appropriate input and output pins, whether the fan control module will work in your application, if you have the right input sensors, etc.
Like I've said earlier, first time retro-fits are like the old whack-a-mole game. Solving a problem in one area can cause another problem to pop up somewhere else in the system. It can often be an interative process with inherent tradeoffs.
Unless you are a gluten for punishment or just like the challenge of figuring things like this out yourself, getting the advice of or hiring a professional is highly recommended. That is exactly why we plan to follow Dave's trail as much as possible.
I am definitely not a professional or experienced resource. I'm just a fellow newbie trying to validate what I think I am learning as I go.
Good luck!
Old 02-26-2013, 12:50 PM
rusty63ss's Avatar
Thanks for the reply. Maybe when I get further in my project I'll play with it and see what I can get done.
BTW your engineering degree is showing.
Old 03-05-2013, 02:37 PM
Originally Posted by John
If the V/A (or ISIS) controller manages the compressor, then there must be a sensor to know when to turn off the compressor when liquid side pressure gets too high. So we're back to a trinary switch (maybe just a binary switch?) to do that -- negating one of the key advantages of having the ECM manage the fan. I suppose it's still better for the ECM to manage the fan (does it soft-start the fan to reduce inrush?), but this hybrid system will have two pressure sensors that aren't integrated.
I'm going to talk to ISIS about their V/A controller and whether or not it can be modified to support the CAN-bus protocol to be able to talk to the ECM. I'm sure Jay's question will be: what is the CAN-bus sequence to tell the ECM to enable the A/C clutch?
Edit: I realize that just the CAN-bus electrical connection isn't enough. GM has a proprietary protocol that would have to be reverse-engineered to get this to work. I also asked ISIS about their ability to read CTS and A/C sensor data and manage the fans. I'll report back.
Here's the report back from ISIS:
Originally Posted by Mike from ISIS
We do have a J1939 interface on a version of the Mastercell but that is only to read PGNs sent to the Mastercell by other devices (We buy switch packs that communicate J1939) and does not send commands out at this point. The GM ECM would have to communicate using standard J1939 which I don't think it does and we would have figure out how to send the proper commands over the J1939 bus.
So does anybody know: does the GM E67 use J1939 protocol over CANbus?
John Parsons
