Old 06-26-2013, 07:07 AM
Smoker03's Avatar
Smoker03 Smoker03 is offline
I received the revised 1st gen F-body arms yesterday. They look great. They only come with the zero offset slugs, so I'll have to order up some of the offset slugs to get the caster where I need it. Other than that they seem to be a very high quality piece. I just got off the phone with Ridetech and they are sending me the offset caster slugs. That is excellent customer service and product support. Light years ahead of my previous suspension supplier.
Old 06-27-2013, 05:17 AM
Hmmm. The temptation builds. Me want...
John
'71 Nova (Build thread)
FFR Roadster
Old 06-27-2013, 09:00 AM
Smoker03's Avatar
Pull the trigger. I am very happy with the quality of their parts. I've used a mix bag of parts before on other cars that worked, but a fully engineered system is the way to go. Do it once and do it right. You will save time and money in the long run.
Old 06-28-2013, 02:23 PM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
At 2012 SEMA it was announced that all strongarms would go delrin. I was pretty psyched as I had just acquired my B-body. Apparently, the announcement isn't really true? From this thread it seems there isn't a rollout plan to convert all types? I'd be happy for a projected date!
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 06-28-2013, 06:18 PM
camsdad's Avatar
camsdad camsdad is offline
Is there or will there be a set available for a 1st gen f-body using 3" drop coil springs and shocks?
Kurt
1969RS Holly Molly! Its Done!
Dart SHP 400, Holly Terminator X Stealth EFI , 200R4 Trans, 3:42 Posi 12 Bolt axle, Cold ones in the fridge Dam, all gone Be right back!
Yeah Baby!
Old 06-28-2013, 07:07 PM
Supporting Vendor
Rick,
I apologize if we were unclear at SEMA.
The Delrin bushings are designed as a direct replacement for our poly bushings. As such, any control arm that has a poly bushing will be changing to Delrin as soon as we can get everything changed over.
However, some of our control arms were designed to use the OE style rubber bushings. (especially control arms that use the OE cross shafts, like the 58-64 Impala, tri-5 Chevy, etc). The 65-70 B-Body uses rubber, but we make the cross shafts, so the change is easier. We just have to go through all the applications we have and re-design everything to fit the new bushings, then test fit them on a vehicle to make sure it all works. Since Delrin does not "move" it is very "dimension critical" to make it fit in the vehicle. I will not release a part that we "think" will fit. . .we have to know for sure.
Most applications will change. . .but some may need to retain the OE rubber bushing. For example, the 58-64 Impala uses an odd cross shaft that is "bent" in the middle to allow clearance for the steering shaft. Obviously these are much more "design intense" and will require more time.
Skunk Werks
Ridetech
www.ridetech.com
Old 06-28-2013, 07:10 PM
Supporting Vendor
kurt,
At this time we do not offer a control arm that uses a "stock style" coil spring and shock. Everything we do is for Shockwaves or coil-overs.
There may come a day when we make traditional "large spring, small shock" control arms, but it's a ways off.
Skunk Werks
Ridetech
www.ridetech.com
Old 06-28-2013, 07:39 PM
Originally Posted by marolf101x View Post
Rick,
Thanks alot for the clarification!
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 06-28-2013, 07:56 PM
camsdad's Avatar
kurt,
That's what I figured.... Damm!
Thank you for your reply.
Kurt
Yeah Baby!
