Old 10-09-2014, 10:47 AM
Ron in SoCal's Avatar
reserved for track day report.
Reserved for Jack Daniels, just in case he ever shows up
Ron in SoCal
69 Camaro in progress
Old 10-09-2014, 03:52 PM
Vince@Meanstreets's Avatar
Me and Jack go way back and I can tell you it was not pretty. Fun, but not pretty.
Hope to see some GoPro action soon.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 10-09-2014, 06:47 PM
payne payne is offline
Driving home. Will get video up in the next few days. She goes like hell and the car just works really well. I freaking love the car.
I thought I was going fast. Then I rode in my buddy's GT3 cup car and turned some 1:55s.
The good news is that the cup car tires are 275 and 315 and the exact same height as the current tires so I can run his pull offs. So I got sticky tires figured out.
Now I just need better brakes... Absolutely roasted em by my last session. Had the pedal go to the floor on my last hot lap and had to pump during the cool down. Spooky. And I need a bigger oil cooler.
Meh on the Jack. I'm a burbon guy.
Old 10-09-2014, 09:45 PM
Good to hear and can't wait to see the vids.
Them ole Wilwoods def need an upgrade.
Me and Jim Beam don't get along.
Dealer for
NEVER FORGET -11
Old 10-10-2014, 05:06 AM
Rick D's Avatar
Rick D Rick D is offline
We need the video or it didnt happen
Rick
Old 10-10-2014, 10:55 AM
Vince-
Looks like the high temp may be a bad ground adding resistance. Will start there and then check the sensor resistance if it's not the ground:
http://www.stangnet.com/mustang-foru...inside.539706/
http://www.autometer.com/tech_faq_an...x?sid=1&qid=57
Cheers,
Jason
PS - video is not great mounted the go pro too high in the cage so you don't get a ton of track in the video, mostly cockpit.
Old 10-10-2014, 01:29 PM
Originally Posted by payne View Post
Found the issue with the oil pressure gauge - the fuel level gauge 12V was tapped off the oil pressure power and causing interference. Unplugged the fuel sending unit and all good. Will re-route power for the fuel level and should be in good shape.
Vince- So if I switch to speedtech upper control arms I should have a lot more steering articulation? That seems like a much better fix than spacers or new wheels. Is the geometry substantively different or are the current control arms significantly better? I assume I'd have to realign after the swap?
Thanks,
Jason
L
Vince-
Cheers,
Jason
Makes sense, I'd rather see the sender in the filter block too
Dealer for
NEVER FORGET -11
Old 11-29-2015, 04:35 PM
seancarole seancarole is offline
Any updates with this fat booty grocery getter???
Sean
Old 11-30-2015, 12:19 AM
RPitts's Avatar
RPitts RPitts is offline
Nice car! Are you doing tack days at thunder hill? I have a buddy that has a white GT3 from Sacramento wonder if it's the same guy? I have learned a ton from this site and everyone seems to be really helpful. Met a few of the guys on here in person fun group. If you get a chance you have to do one of the Optima events!
Old 11-30-2015, 05:57 AM
Corey R. Corey R. is offline
Most of your pics are failing to link.
Any links to your Forester build?
