Old 02-10-2016, 03:43 PM
atomicjoe23 atomicjoe23 is offline
Default DSE vs. SpeedTech Performance. . .
Has anyone seen a no BS real comparison between these two companies products???
Like DSE's A-arm set-up vs. SpeedTech's A-arm set-up, or a direct, real world (same car/driver, same tires, same rear suspension so that all you are comparing are the differences between the companies front end packages) comparison between the two subframes (or three now that there is the ExtremeR subframe SpeedTech)?
It's easy to look at the pictures and read the text, but trying to figure out which subframe or suspension set-up you want is frustrating if you can't compare apples to apples. . .
. . .just wondering if anyone knows if such a test has been done.
Thanks!
'67 Pontiac Firebird 400 RA coupe
http://www.pro-touring.com/forum/showthread.php?t=26557
'97 Chevy Camaro 3.8/M5 coupe
'02 Yamaha R1
'01 Aprilia RS50
'00 Yamaha R6
