Old 01-17-2017, 01:55 PM
Merritt5 Merritt5 is offline
Default 1993 Fox Body
Figured its time to start a thread on this car.
Picked this car up last year for around $1200. The guy before me swapped in the 5.0 and 5 speed, along with a rear from a 98 stang. Had a little brake issue and need to fix a few small issues.
I completed the 5 lug swapped and upgraded the brakes to sn95 components.
Someone added stop leak to the motor , so I swapped out the heater core and radiator, then flushed it for days!
Here is a few pics from when I picked her up.
Old 01-17-2017, 02:03 PM
Here she is with new shoes! They are 18X10's with 285's on all four corners...and I do get a slight rub in the rear
Also swapped that hood with the ugly scoop for a stock one.
The swapped hood
And how she looks now...This was on a trip through the tail of the dragon
Old 01-17-2017, 02:12 PM
Also installed a solid steering shaft after the old rag joint broke on me. Its always a nice feeling when you hear a pop and gain some slack in your steering.
Next on the list is subframe connectors and possible some Datsun Z flares.
Future plans:
For the rear, I a plan to design a 3 link setup and add a panhard bar.
For the motor, I have a lq4 and t56 that I have sitting in my parents garage...along with a 4in crank. So I am on the fence about swapping it into this car or saving it for another project. Decisions decisions
Old 01-17-2017, 03:33 PM
DBasher's Avatar
DBasher DBasher is offline
I dig it! Is the 98 rear set up any wider...it's not IRS is it?
Looks good, much better with the new hood.
Old 01-17-2017, 03:37 PM
Nice! Car looks to be in rather good condition overall. I'm happy to see 5.0 Mustangs and 3rd gen Fbodies get some attention.
I say go stroker LS and have fun. I also vote for 93 Cobra spoiler. Love that spoiler.
Old 01-18-2017, 11:53 AM
Flash68's Avatar
Flash68 Flash68 is offline
Yes!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 01-17-2017, 05:12 PM
It's a solid axle. It is slightly wider, but I believe it's mostly from the axles having the wheel speed sensors.
Old 01-17-2017, 07:12 PM
wiedemab's Avatar
wiedemab wiedemab is offline
SN95 rear axles are .75" wider per axle for a total of 1.5" if I remember correctly. You can change out the axles and use brackets from North race cars with the SN95 rear brakes to get the narrower width. I basically replicated the M2300K kit on mine with the exception of staying with the narrower rear.
Brandon Wiedeman
'72 Suburban
'67 Chevy II -
