Old 02-01-2019, 07:41 PM
mfain mfain is offline
Finally got the motor on the dyno. 852.71 peak HP @ 7100 rpm, 685 peak torque @ 5900 rpm. Should be enough.
Pappy
Name:  Motor on dyno 3 (2).jpg
The Following User Says Thank You to mfain For This Useful Post:
syborg tt (09-05-2020)
  #32
Old 02-01-2019, 09:29 PM
Flash68's Avatar
Flash68 Flash68 is offline
Jesus, that is outstanding.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
The Following User Says Thank You to Flash68 For This Useful Post:
mfain (02-05-2019)
  #33
Old 03-02-2019, 08:09 PM
Not bad for an NA motor. The AFR was a little fat, especially 3500-4500 rpm, and the timing was only at 34 degrees, so there was a little more to be had with tuning. I will do that when I get it on the chassis dyno.
Pappy
Name:  56 Corvette Dyno.jpg
Old 03-02-2019, 09:08 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
Wow!
Ric
2002 S-10, Daily Driver and autoX
1966 Chevelle MALIBU ( mine since 1971) Drag car converting to a track car!
The Following User Says Thank You to rixtrix1 For This Useful Post:
mfain (03-04-2019)
  #35
Old 03-03-2019, 02:44 AM
Beechy's Avatar
Beechy Beechy is offline
Default Bruce jenner fanboi
Originally Posted by rustomatic View Post
This looks interesting. So a C4-type suspension is also called a five-link, I think, and the DSE setup is called a "decalink," which sounds like a Bruce Jenner-style update (the Olympics version, not the modern one). It's hard to tell via DSE's site, but is there now some semblance of an upper control arm? Aside from that, it looks very similar to the C4 setup (with batwing!), which I recently learned was largely pirated from early Indy car-type setups (makes me feel better about my C4 stuff) . . .
Nice stuff!
So...Paul.....
"deca" being the Roman prefix for "ten"......i.e. 5 links per side.....q.e.d.
Thank God for the Romans....
Bruce Jenner...not so much
Jim Grant
Melbourne, Australia
(Dual citizen)
Old 03-03-2019, 05:58 AM
SSLance's Avatar
SSLance SSLance is offline
Pappy
Attachment 68516
Goodness gracious!!!
Lance
The Following User Says Thank You to SSLance For This Useful Post:
mfain (03-04-2019)
  #37
Old 07-14-2019, 05:43 PM
Haven't posted in a while. Finished up the Decalink rear suspension and rebuilt the trunk where I cut it up to do the rear suspension install. Added a fuel door in the deck lid so I didn't have to open the trunk (with the wing and supports that run through to the frame) every time I refueled. Cut the firewall out to move the motor back 6 more inches (for a total of 15) to get clearance between the dry sump pump and the lower control arms. Turned out to quite complicated since I had to modify the x-member to get clearance for the rear mounted starter motor and so I could pull the transmission from below the car instead of out through the cockpit, but I'm getting it done. Looks like my driveshaft will be 19 inches long - LOL
Pappy
The open 3 inch holes get air hoses that bring air from the side scoops to the differential and fuel coolers.
Name:  56 Corvette Trunk 10.jpg
Firewall before the cut
Name:  56 Corvette Firewall before.jpg
Tilton Bellhousing
Name:  56 Corvette Firewall 6.jpg
Reverse mounted starter
Name:  56 Corvette Firewall 7.jpg
Name:  56 Corvette Firewall 8.jpg
Old 07-14-2019, 06:23 PM
I also got the fuel cell from Fuel Safe. 19.7 gallons, 1.76 gal sump with trap doors, Aeromotive 1000 pump.
Pappy
Name:  56 Corvette Fuel Cell 2.jpg
  #39
Old 07-15-2019, 04:27 AM
SSLance's Avatar
Need to get over and see this in person sometime Pappy. Looks great!!!
Lance
mfain (07-15-2019)
  #40
Old 07-16-2019, 01:52 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Pappy
Attachment 68516
Well, that should be FUN!
http://bestofshowcoachworks.com
(760)480.0227
1969 Camaro - always broken GM Design winner
1965 Mustang - widebody fastback
2006 Coyote swapped "Rental Car"
Up next:
Steve's GT40
