Old 06-17-2025, 10:57 AM
dhutton dhutton is offline
You're definitely a brainiac Don...
Ya no… . I was navel gazing and wondering if the resonant frequency of the arm was anywhere close to the driveshaft or axle speeds.
We need a real engineer like Stielow to weigh in… . Or Donny likely has an idea on this.
The Following 2 Users Say Thank You to dhutton For This Useful Post:
camcojb (06-17-2025), cpd004 (06-17-2025)
  #32
Old 06-17-2025, 11:12 AM
cpd004's Avatar
cpd004 cpd004 is offline
Stielow is an FN988 guy as well in his latest build.
I believe they tossed around a few ideas at Donny's shop. Ultimately it would have been a trial and error and see what works thing. If he does think of something to try, I'd be all for it.
I would not go Speedtech for the rear again. Go Detroit Speed. The front is another story.
1971 Firebird
2017 SS
Old 06-19-2025, 07:25 AM
cpd004's Avatar
Donny, if you have both the 9" and FN988 can you post a side by side? Interested in how much more aside from the pinion support would have to be made to swap the 8.8 into the Speedtech torque arm.
Are the bolting locations in the same place (distance) from base of the housing?
1971 Firebird
2017 SS
The Following User Says Thank You to cpd004 For This Useful Post:
camcojb (06-19-2025)
  #34
Old 06-19-2025, 07:35 AM
dontlifttoshift's Avatar
Donny
The Following 4 Users Say Thank You to dontlifttoshift For This Useful Post:
camcojb (06-19-2025), cpd004 (06-19-2025), dhutton (06-19-2025), syborg tt (06-25-2025)
  #35
Old 06-20-2025, 05:57 PM
TBART70 TBART70 is offline
That really sucks, I have a 9" with 3.70 gears, luckily I don't have any noise
. Looks like I might need to be in the planning stages for tunnel mods.
Thanks for the responses and info.
Hopefully you figure out the noise.
The Following 2 Users Say Thank You to TBART70 For This Useful Post:
camcojb (06-20-2025), cpd004 (06-21-2025)
