Old 04-20-2007, 09:05 AM
steveo346's Avatar
steveo346 steveo346 is offline
Default 71' formula firebird ($3,000)obo
71 formula firebird, has dual snorkel fiberglass hood,the interior has been stripped...has tilt column with formuls wheel.....i have the original gauge cluster but it needs a circuit board....mods are as follows...
400 pontiac
offenhauser aluminum intake
650 holley dual feed zinc finish
msd pro billet distributor
msd 6a ignition box
msd coil blaster with chrome cover
moroso chrome valve covers
accel race wires
11.1 je forged dome pistons
childs and albert bearings and piston rings
crower hydraulic roller big cam, not sure on specs
pete jackson timing gears
blackjack tri y headers which need to be replace cause they suck
march aluminum crank,alternator,and waterpump pulleys
black flex-a-lite fan
4 core radiator
new booster
new master cylinder
disc front brakes, rear drums
eibach front lowering springs
polyurethane tierod end bushings
polyurethane upper a-arm bushings
polyurethane lower a-arm bushings
polyurethane body mount bushings
polyurethane tranny mount
350th with shift kit
3000 b&m stall
b&M adjustable shift cable
spooled 10 bolt rear
10 gallon fuel cell in trunk, have stock gas tank if you want
spare trunk lid
rci plastic racing seat
ok now the bad part, i purchased the car from a friend and when he owned it he never had registerd it and he lost the title....so i dont have a title...the vin is clean and not stolen nor slavaged...i just dont have the title in hand
www.titlesunlimited.com
www.broadwaytitle.com
those are some links that can help u get a title
thats all i can think of at the moment
will post pics tomorrow
2001 camaro z28
1972 camaro ss
1971 formula firebird
1991 camaro z28
1991 camaro rs
too many fbodies...
Old 04-20-2007, 09:56 AM
steveo346's Avatar
here a few pics, im at work so dont have many pics here....will post them when i get home
things car needs....
taillights
front park lens
rear shocks
brackets for rci racing seat
curcuit board for original cluster
wipers
2001 camaro z28
1972 camaro ss
1991 camaro z28
1991 camaro rs
too many fbodies...
Old 04-20-2007, 01:17 PM
where are you located?
Old 04-20-2007, 03:47 PM
4mm 4mm is offline
Car is in Laredo TX 78045.
Old 04-20-2007, 05:24 PM
sunset68's Avatar
sunset68 sunset68 is offline
Hey Steve,
How much for the white SS behind the firebird? I'll give you 15g's.
68 Sunset Orange Metallic Camaro
Old 04-21-2007, 10:52 AM
gearheads78's Avatar
gearheads78 gearheads78 is offline
Saw this on another board a month ago. Supprised its not gone yet. Good luck with tthe sale.
66 Cutlass "Joe-Touring"
54' Olds 88 "Joe-Touring 2.0"
69 SS Camaro 4-speed (wife's)
Richard J.
If only I had the time talent and money to build everything in my head
