Closed Thread
Old 11-16-2008, 07:04 PM
She is pretty clean...plan on many more miles soon. Next is the trunk carpet and box for my subwoofer. Then it's plug and play. Should have a really good sound system. Then I am on to finishing the interior. Back seat, rear panels, and AC/Heat. This flywheel deal put me behind.
  #402
Old 11-16-2008, 08:50 PM
Tom.A's Avatar
Tom.A Tom.A is offline
Todd,
Good to hear the vibration is better but it sucks it's not gone. I am sure the guy's a CC5S likely went over this but I was just thinking that you changed the sub frame mid-build and went with the DSE unit. Did you order your TKO kit prior to that? CC5S has two cross members for first gen camaro. Standard SBC and a big block which is offset. The BBC cross member would only apply if you either had a factory big block car or you changed the SBC engine stands to the BBC ones. Perhaps all this gets thrown out the window with an after market sub? Just thought I would mention that as you have widdled down all the other things that relate to this kind of issue.
Tom
  #403
Old 11-17-2008, 06:41 AM
Thanks Tom....I actually ordered a small block crossmember. Due to my half height body bushings I had to make it a two piece design. It seems to be square.
  #404
Old 11-23-2008, 08:40 PM
70 and sunny today...not a cloud in the sky. Polished her up and out to the middle of nowhere on the Arizona side of the lake. Broke the 1000 mile mark today and got a quick video. Road was not the best so I was taking it easy. I still can't get over just how nice it rides yet handles like my Corvette.
  #405
Old 11-23-2008, 10:15 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Looks like fun!
Curtis
  #406
Old 11-24-2008, 06:32 AM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
Looks good under there man!
I agree!!!!
  #407
Old 11-29-2008, 05:03 PM
Part of building these things is tuning and lot's of it. Built from scratch means tweaking this and that to get things optimal. I've had a tip in hesitation since day one, my plugs are burning a little fat, and my radiator recovery system needed some work.
With a MSD Pro Billet distributor you have no vacuum advance. With a large camshaft that means low vacuum at idle. To help with vacuum and signal to the carb you want as much intial timing as possible. The problem is as you increase intial you increase total. Today I pulled my distributor apart to find a 21 degree bushing and the heaviest springs MSD makes. Not optimal by any means. I replaced the bushing with the black 18 degree and used the blue springs. Now advance will come in 500 rpm sooner and I can add 3 degrees initial timing.
My engine was dyno tuned in NC. I am at 2500 ft elevation and in a drier climate. I have used formulas in the past to change jets on my quad. Basically I needed to jet down .002 front and back to 79/87.
I was using a catch can which would probably work for some. With the half height body bushings it does make your engine set higher in relation to the radiator. Basically what would happen is I would top it off and drive it, as the coolant expanded it would go in the catch can . Well after a few drives the coolant would get low enough it would get an air pocket in the intake at the sensor. No problem if I topped it off ever couple times. Now I have a recovery style resorvoir. It will pull the expanded coolant back as it cools like a new car.
So I rejetted and reset the float levels, adjusted the air mixture screws and added a few degrees of initial timing. Car has never run better or smoother. In fact it's helped my vibration at freeway speeds 85-95. The poly engine mounts go in next and that will eliminate almost all of that. Tip in heistation has vastly improved. Probably going to have to send in the metering blocks to get rid of it 100%. For now it's 100% better than before all the tweaking. All and all one of the best days of work yet. Just keeps getting better!
  #408
Old 11-29-2008, 06:38 PM
awr68's Avatar
awr68 awr68 is offline
Good deal Todd! Post pics of your recovery style resorvoir plumbed.
Keep at it!!
Tony
'68 Camaro
  #409
Old 12-03-2008, 02:16 PM
Well it looks like I'll be without a car for 3-4 weeks. Dropping her off at www.findlaycustoms.com Monday to finish off the car from the front seats back. Back seat, rear quarter panels, sub box, trunk, probably tune the stereo and possibly recover the door panels, shorten the seat belts. Every time I walk out in the garage I turn the key instead of work on it. This stuff is out of my leauge anyway. It's going to suck to be without it but it's time to finish the car.
  #410
Old 12-03-2008, 05:16 PM
skatinjay27's Avatar
did you do a good sale lately??
i got a pretty good idea what the bill is gonna be for that! lol
did you get the material for the rear seats? are they just gonna cover stock one on go crazy with some customs. its gonna be killer they work is top notch, cant wait to see it todd. be sure to call me when it done so i can come see it!
AJ
Closed Thread
