Old 06-03-2020, 09:12 AM
DKz Garage's Avatar
DKz Garage DKz Garage is offline
It is built into the end tank of the C&R radiator. Oil to water heat exchanger.
Works great.
I also use a oil adaptor with a built in thermostat. Improved Racing makes one as well as Holley.
Thank you as always Mark!
Old 06-03-2020, 10:47 AM
jmac jmac is offline
I would be interested to see your plumbing from the side of the block from the Holley thermostat piece up to the radiator. I'm interested in how you routed it and what you used to transfer the oil.
Thanks!
My 1967 Camaro
Old 06-05-2020, 04:38 AM
Stielow's Avatar
Stielow Stielow is offline
Thanks!
We will get some photos during assembly. Basically -10 AN hose. Fairly straight forward.
Stielow Engineering
Old 06-05-2020, 04:40 AM
Stielow's Avatar
The Dutchboys are done with the final block sanding. Now it comes apart to get put on the rotisserie to prep the bottom and the firewall.
Stielow Engineering
Old 06-05-2020, 09:04 AM
Stielow's Avatar
Stielow Engineering
Old 06-06-2020, 07:11 AM
Stielow's Avatar
Working on cleaning up the wiring on the LT5 crate harness. The LT5 uses 2 ECMs.
Lots of wires
Stielow Engineering
Old 06-06-2020, 04:25 PM
F'in mine's Avatar
F'in mine F'in mine is offline
I guess the 2nd ECM triggers the other new port injection system. How are they activated, engine rpm?
1969 Camaro SSRS
Simon
Old 06-06-2020, 06:44 PM
That's what I'm wondering, too, Simon. I didn't realize these engines had two ECU's
Old 06-07-2020, 04:21 AM
Stielow's Avatar
The 2nd ECM S53 is basically a slave ECM that drives the 8 extra Port Fuel Injectors. It is controlled by CAN messaging from the primary E99 ECM. The engine calibration lives in the E99 ECM.
This is needed because a LT5 has 8 Direct Injectors and 8 PFI injectors.
HP Tuners has cracked into the ECM so now you can tune it.
Stielow Engineering
Old 06-11-2020, 09:00 AM
Stielow's Avatar
More progress at the Dutchboys
Stielow Engineering
