Old 10-25-2006, 07:40 PM
syborg tt's Avatar
Originally Posted by TravisB
take care of yourself marty........feel free to call if you get bored laying around recovering.....
trust me i plan to be typing away and working on the build book for syborg
marty-mj
Old 10-25-2006, 08:00 PM
syborg tt's Avatar
A couple people have asked what's left before paint at KD Hot Rods. Here is the list that Dave and I are working off of.
To Do Paint & Body
Patch Panel underside of Bed
Billet Bed Shims
Smooth Welds on Inner Fenders of Bed
Smooth Tailgate Handle (Just tacked in)
Adjust Hinges on Tailgate
A-Pillar Body Line
Hood Hinges - Possible Billet
Remove Hood Body Line < (= End Body Line on Front Fender >
Inner Fenders - Smooth
Radiator Cover Shroud
Remote Wiper- Complete
Roll Fender Lips on all Four Corners
Interior
Sheet Metal Dash Conversion (Side Panels)
Mount Gauges
Re-Drill Steering Column
Mount Lokar Hood Release
Mount MSD Coil ( Firewall )
HID Headlight Conversion or H4 Conversion
To Do Engine Bay
Billet Master Cylinders
Mount Over Flow Bottle
Mount Power Steering Tank
Mounting tab on Hogan Intake Valley (FPR)
Turbo Support Bracket
Mount AC/Heat Bulkhead
Mount AC Dryer
A/C Condensor Clearence Grille
Radiator Cap
Install Oil Fill Cap / Spout in Manifold
To do Plumbing
Stainess Brake Lines
Braided Stainless Lines on Trans Cooler.
Braided Stainless Oil Cooler Lines
Y-Block to Engine - back to Fuel Cell
Temp Sender - Radiator (keep one hole open)
Upper Radiator Hose
Lower Radiator Hose
PS Lines
Air Lines (Air Ride)
Shifter Cable
Transmission Dip Stick
Electrical Lines
Starter
Remote Battery
A/C Plumbing
To Do Chassis & Suspension
Misc Underside Welding
Cross Brace
Smooth Welds on the Frame
Tie Rod Sleeve (Talk with Kevin)
Bump Stops on Chassis - Front Suspension
Longer Wheels Studs - Front Spindle's
Drive Shaft
Ground Studs - Firewall, Front Frame, Rear Frame
Ground Studs - Interior firewall, Pump Controller, Radio, Amp, MSD Box
marty-mj
Old 10-31-2006, 06:29 AM
syborg tt's Avatar
Good Mornig All,
I would like to welcome Vintage Air to the sponsor list.
We look forward to working with them on this project.
We wanted a control unit for the dash that would work with our project.
It's ultra clean and simple looking.
Previously installed in the Vintage Air Heat, Cool, Defrost Gen II Mini
More to come next week.
Seems like i just spent a couple hours ordering parts this week.
marty-mj
Old 11-05-2006, 08:32 PM
syborg tt's Avatar
Good Morning All,
Well, this will be the last update for a couple weeks as the big day is Tuesday Morning.
Pictures don't do it Justice. Man are these tires huge!
Notice the tire is almost the same height as the body line at ride height.
Just like the picture.
PS that is one bad viper hanging in the air. About 300k invested so far.
just a quick side shot.
okay last one i promise
marty-mj
syborg tt's Avatar
Now you can see what the chassis looks like.
Here is all of the Air Ride Equipment
Dave installed the new Vintage Air Billet Defrost Ducts.
Underside view. The ducts are temporally being held in by sheet metal screws.
A little more trimming was needed on the dash so it would clear the door panel.
Although we are not using the stock door panels they were used as a guide
marty-mj
Old 11-05-2006, 08:33 PM
syborg tt's Avatar
Yep that's a bunch of guy's looking at an upside down bed
Yep that's the stink can there Dad.
Dave also trimmed out the inner fenders and closed the gap.
That's all for this week. I hope to be back online by the weekend.
marty-mj
Old 11-05-2006, 08:35 PM
Looking good Marty. That first pic is a little scary. As it looks like there would be some serious rubbing issues with the tank. But the side shots clear it up!! Those things are HUGE. I own a 2003 Dime, and couldn't imagine those things on my truck....on second thought...yeah I could
edit: I also like the way the roll cage ties to the cab very trick!
1/12th scale 1969 Sunset Orange Metallic Camaro Pro Touring Style>>
Progress Thread
Artwork Page
Old 11-05-2006, 08:37 PM
syborg tt's Avatar
yep they are monsters. I can't wait to see them rolling down the street.
marty-mj
Old 11-06-2006, 06:07 AM
Good luck and a speedy recovery Marty! We'll all be anixously waiting the next update.
Jeff Allen
J2 Speed and Custom
Old 11-06-2006, 06:13 AM
Rebird's Avatar
Rebird Rebird is offline
Unreal truck!!!! Attention to detail is amazing!!! WOW!!!
