Old 04-12-2020, 08:49 PM
Wow what a nice finish! I like that so much more than the ruff finish. Beautiful job.
Old 04-12-2020, 09:36 PM
Roscoe03 Roscoe03 is offline
That looks amazing! Nice work.
Old 04-13-2020, 04:46 PM
two-piece's Avatar
two-piece two-piece is offline
Looks killer
Old 04-13-2020, 07:28 PM
Fantastic! Great job, John!
Old 04-14-2020, 10:50 AM
streetbird's Avatar
streetbird streetbird is offline
wow I love the finish of the liner that way. What gun you taked for that?
What is the equivalent in mm for the .22 tip? and last question, what you taked to disolve the liner.
The French Frog
Old 04-14-2020, 07:19 PM
Goosesdad's Avatar
Goosesdad Goosesdad is offline
Originally Posted by two-piece View Post
Looks killer
Thanks guys!!
No real fancy gun..Devilbiss Finishline. Think it's a $200 gun.
Tip sizes are in mm. So that is a 2.2mm tip.
I used PPG DT885 reducer. It's pretty expensive for this... I think you could use any good urethane reducer.
Pressure and material volume adjustments make the texture and thickness. This was my first time spraying it and I'm a total rookie with the gun. Honestly, it was very forgiving and responded well to adjustments including pattern. I dialed it tight for small areas and then to around a 4" spread for flat areas. Don't mess around after you are done spraying...get to cleaning the gun!!!
Have a great day!
John
My Build Thread:
https://lateral-g.net/forums/showthread.php4?t=53320
Old 04-14-2020, 10:28 PM
camcojb camcojb is online now
Originally Posted by Goosesdad View Post
Thanks guys!!
I love that liner, had it on my Chevelle. Very clean and uniform look, and is awesome at hiding dust and debris on a car that's driven.
The Following 2 Users Say Thank You to camcojb For This Useful Post:
Goosesdad (04-19-2020), syborg tt (12-28-2020)
  #418
Old 04-15-2020, 06:08 AM
streetbird's Avatar
Thanks for taking time to respond.
I will try it soon, I got dt1855, I suppose it will do the same job as the dt885.
The French Frog
Old 04-19-2020, 08:52 PM
Goosesdad's Avatar
Powder coated the rear-end.
Syringed in a little gun metal gray (color matched to the wheels) into the Currie letters, just for fun.
Have a great day!
John
My Build Thread:
The Following 3 Users Say Thank You to Goosesdad For This Useful Post:
CamaroAJ (04-20-2020), Roscoe03 (04-20-2020), syborg tt (12-28-2020)
  #420
Old 04-21-2020, 06:43 PM
Goosesdad's Avatar
Long, long way to go here but here is the start of the headliner/A-piller panels. Capitalizing on it still being on the rotisserie.
Have a great day!
John
My Build Thread:
The Following User Says Thank You to Goosesdad For This Useful Post:
