Old 06-09-2015, 01:43 PM
garret805's Avatar
garret805 garret805 is offline
Originally Posted by Chad-1stGen View Post
And here is video of my fastest runs for each of the three events.
Sounds damn good.
Old 06-23-2015, 01:49 PM
Jr's Avatar
Jr Jr is offline
Chad ,
Do you have any pics of how your exhaust was installed? Especially the rear...
Old 06-24-2015, 05:58 PM
Chad-1stGen's Avatar
Chad-1stGen Chad-1stGen is offline
Originally Posted by Jr View Post
Chad ,
Hi Jr.
The closest thing I can find right now is this pic.
If you need to see something else, let me know.
EDIT: It BARELY fits in the rear with 3" tailpipes.
Autocross and Track blog
Lots of autocross & track day videos of my car: https://www.youtube.com/user/TheDude023
Old 06-24-2015, 07:18 PM
jlwdvm jlwdvm is offline
Are you running a baffled oil pan, accusump,etc with your LS? Are you having any oil pressure problems at the track?
Old 06-24-2015, 10:19 PM
I'm running an autokraft oil pan which has 4 trap doors rather than just baffles, the windage tray that comes with the GM hot rod pan and a large oil cooler which also added a little more than a quart of additional capacity.
So far I've had no serious oil control problems. I say that based on never seeing the oil pressure gauge drop in a turn on track though to be fair my attention is usually elsewhere. But I also take a lot of comfort in the fact I've also never had a low oil pressure code. My Mast M90 ECU will trigger a code if the oil pressure drops below 15 or 12 PSI (can't recall the exact number) so I know for sure I've never had a total loss of pressure from cornering.
I'm still considering an accusump though.
Old 06-25-2015, 09:02 AM
It had been a while since I went through your thread, but I seen that you were using an aftermarket pan. I have a Texas Speed 570 hp LS3 in my 69 firebird with the Holley 302 pan. I got my hands on their new trap door pan insert that I will be installing after I drop the sub and pull the motor....I haven't fired the motor yet. I also have an Accusump 3qt to plumb in. I will be using my car similar to what you are doing.
Old 06-25-2015, 09:43 AM
Sounds like a good plan. I saw the improved racing insert recently and that is a great alternative to buying a whole new pan. I haven't seen the Holley one but if its similar it should work great.
If you are going to be doing track days with 20 minute road course sessions I would recommend an oil cooler. Even 10 minutes on a road course heats my oil up a LOT. At minimum get an oil temp gauge and get one that goes higher than 250* (280* minimum) so you can see what is happening.
Old 06-25-2015, 10:21 AM
I thought Improved Racing is who came up with the pan insert for the 302 pan, but it is sent in Holley packaging. I have a C&R rad with built in oil and power steering coolers. I went with an Improved Racing thermostat that bolts up to the pan. I will be keeping tabs on the motor with a Racepak dash with warning lights.
http://www.pro-touring.com/threads/1...rack-car-build
Old 06-25-2015, 10:23 AM
cwylie cwylie is offline
Custom built exhaust I assume?
Old 06-25-2015, 03:41 PM
Sounds like some great parts! I will have to check out that thread at home as PT.com is blocked for me at work.
Yes that is a custom built exhaust.
