Old 06-01-2009, 11:15 PM
6D9 6D9 is offline
yeah man I will keep hitting up Jason to set something up, and if not, a few of us can just go up there sometime. I know Mike P wants to take his newly finished Camaro up there too after some dyno tuning, which we both plan to do very soon.
You gonna run 100% meth of a mix of water/meth?
Most likely around 70/30 mix.
70..water
30..meth
I sold my 18's awhile ago so its now on my 15" set up so it will be ready for the track!
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 06-02-2009, 10:38 AM
Flash68's Avatar
Flash68 Flash68 is offline
70..water
30..meth
A great addition or replacement for intercooler.
Your 69 looks all business with the 15s!
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 06-02-2009, 02:22 PM
6D9 6D9 is offline
Thanks!
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 07-03-2009, 11:44 PM
6D9 6D9 is offline
Any updates??
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 07-04-2009, 09:47 PM
Flash68's Avatar
Any updates??
Damn. It's been a month since I posted. Time flies when you are swamped with work and stuff I guess!
We are nearing the end of the final touches I believe - both cosmetic and mechanical changes in order. Getting some body/paint work done on the rear bumper delete and improving some weak areas of the not-so-great paint job I got from the first builder.
Also figured out a vacuum leak was due to the heads and intake not fitting snug - same exact problem that Mike P had on his Stealth Ram setup. So we got the intake or heads (I forget which?) milled a little to make it fit snug. It would have been a problem later anyway and probably resulted in a big boost loss.
And I haven't had time to get up to Sac recently either, so it's partly my fault. Should be getting up there soon as my temporary registration needs to be finalized before 60 days is up!
2014 4 tap Keezer
Old 07-04-2009, 11:53 PM
6D9 6D9 is offline
Right on...sounds like its coming anlong nice. Keep me posted when you are planning to go to Sacr racway and I will try and meet up with you. Post some more pics when you get a chance....
69 Camaro
491 BBC
TH400/GV OD
Currie 9"
Rushforth Livewires
Old 07-05-2009, 01:56 PM
Flash68's Avatar
Absolutely. Can't wait to see what I can do at a track.
2014 4 tap Keezer
Old 07-05-2009, 05:08 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Thumbs up
That should be a fun day.
Keep us posted on how it went.
Old 07-05-2009, 06:59 PM
awr68's Avatar
awr68 awr68 is offline
Default Are you done yet???????????
Come on already!! j/k...Dave!! I can't really talk can I!
Tony
'68 Camaro
Old 07-05-2009, 07:40 PM
Flash68's Avatar
Absolutely will do!
Yeah yeah yeah. I know I've been a slacker here.... it's another race to be the slowest to get done!
2014 4 tap Keezer
