Old 05-16-2010, 08:38 PM
olds87 olds87 is offline
Dang man you car sound sick.
James W.
1987 Oldsmobile
Cutlass Supreme
Old 05-17-2010, 02:21 AM
evilzee28 evilzee28 is offline
Originally Posted by Steve1968LS2 View Post
Penny did good today.. Ran a 29.6xx which was in the top three i think.. we have an issue with the rear shocks bottoming out.. not good
Will be working with global west to do som tuning an their new Penske line of shocks
Hi Steve, just a query, at the beginning of this thread you said, QUOTE:-
"Bigger on the list was that David thought we needed more shock travel. Seems that were were on the stops durring hard turns and even on acceleration. We worked with Steve Duck over at RaceCar Dynamics and came up with a shock that's over two inches longer. The new Bilsteins are also revalved for the car. The extra length meant that we had to punch holes in the trunk floor so that this mount extender could be welded to the top of the existing brace. The top hole is for future changes if necessary."
Why are you still having trouble with the shocks bottoming out, I thought that this area had been addressed by "punching the holes in the trunk & welding in extenders"? Does this mean that you're changing from the Bilsteins to Penske shocks now? If so what's wrong with the Bilsteins? How much shock compression/travel are you getting with the set up as is? Could it be that your spring rate is wrong allowing an excessive amount of spring compression? Sorry for so many questions, but I'm sure that those people that are following this, wouldn't want to copy your set up & find it falls short of what they want, just as you have.
thanks....Nige
Old 05-17-2010, 07:06 AM
Payton King's Avatar
Default If you are having
trouble getting in first without going to second...I believe you have a bad synchro.
Glad you car is back on the road.
Old 05-17-2010, 07:41 AM
GrabberGT's Avatar
GrabberGT GrabberGT is offline
Wow! That sound! Its intoxicating.
Going to listen again.
Chris
Its not a Vega!!!!
Total Cost Involved - Total Control Products - Gateway Performance - Fatman - MaverickMan Carbon
Old 05-17-2010, 09:24 AM
Steve1968LS2's Avatar
thanks....Nige
Because we keep softening up the springs to make the car more complian.. going from a 310 to 275 rear spring was just enought to cause the new problem.. I think the extra power makes the car want to squat down more as well.
normally we could dial in rebound or compression but my current shocks arnt adjustable.
Moral? get adjustable shocks if your going to do different types of performance events... just make sure you adjust them right
I will know more once Doug Nordin at GW takes a look and some measurements..
Old 05-17-2010, 09:25 AM
How much shock travel do you have available currently?
Old 05-17-2010, 09:27 AM
All of a sudden? Seemed fine back at optima.. then again it was acting up but we thought it was the bent clutch master rod...
Also has a hard time going into first if you are rolling more than 1MPH
not enough! lol
Seriously.. the distance (maybe 4 inches) is only part of the problem.. compression setting is another. with the old springs and power it was fine, barely, but the didnt crash out.
Old 05-17-2010, 09:32 AM
Thanks.. i love the new sound too
Old 05-17-2010, 09:36 AM
No shiat sherlock... I have 2" of compression available with 175's and the RR bottoms but the LR has about a .25 left. Clearly mine is under a full hook left hander. Man, you run stiff springs like the TCI car. No wonder mine rides like a Cadillac.
That was a good tease, I bet you can't wait for a real track!
Old 05-17-2010, 09:50 AM
Doug felt the if the car is this fast with these issues then it should be stupid fast once they are fixed.. even with me driving... lol
